Leetcode 题目解析之 Next Permutation
ruochen 发表于 2022/01/14 13:50:29 2022/01/14
【摘要】 Leetcode 题目解析之 Next Permutation
Implement next permutation, which rearranges numbers into the lexicographically next greater permutation of numbers.
If such arrangement is not possible, it must rearrange it as the lowest possible order (ie, sorted in ascending order).
The replacement must be in-place, do not allocate extra memory.
Here are some examples. Inputs are in the left-hand column and its corresponding outputs are in the right-hand column.
1,2,3 → 1,3,2
3,2,1 → 1,2,3
1,1,5 → 1,5,1
    public void nextPermutation(int[] nums) {
        if (nums == null || nums.length < 2) {
            return;
        int p = 0;
        for (int i = nums.length - 2; i >= 0; i--) {
            if (nums[i] < nums[i + 1]) {
                p = i;
                break;
        int q = 0;
        for (int i = nums.length - 1; i > p; i--) {
            if (nums[i] > nums[p]) {
                q = i;
                break;
        if (p == 0 && q == 0) {
            reverse(nums, 0, nums.length - 1);
            return;
        int temp = nums[p];
        nums[p] = nums[q];
        nums[q] = temp;
        if (p < nums.length - 1) {
            reverse(nums, p + 1, nums.length - 1);
    private void reverse(int[] nums, int left, int right) {
        while (left < right) {
            int temp = nums[left];
            nums[left] = nums[right];
            nums[right] = temp;
            left++;
            right--;
