Leetcode 题目解析之 Missing Number
ruochen 发表于 2022/01/14 13:49:25 2022/01/14
【摘要】 Leetcode 题目解析之 Missing Number
Given an array containing n distinct numbers taken from 0, 1, 2, …, n, find the one that is missing from the array.
For example,
Given nums = 0, 1, 3 return 2.
Note:
Your algorithm should run in linear runtime complexity. Could you implement it using only constant extra space complexity?
既然是0~n只差其中一个数,不如再次加入0~n的序列,这样就和LeetCode 136 Single Number一样了,missing number只出现一次,其余都是出现两次。
    public int missingNumber(int[] nums) {
        int rt = nums.length;
        for (int i = 0; i < nums.length; i++) {
            rt = rt ^ nums[i] ^ i;
        return rt;
