Leetcode 题目解析之 Minimum Size Subarray Sum
ruochen 发表于 2022/01/14 13:48:49 2022/01/14
【摘要】 Leetcode 题目解析之 Minimum Size Subarray Sum
Given an array of n positive integers and a positive integer s, find the minimal length of a subarray of which the sum ≥ s. If there isn’t one, return 0 instead.
For example, given the array 2,3,1,2,4,3 and s = 7,
the subarray 4,3 has the minimal length under the problem constraint.
More practice:
If you have figured out the O(n) solution, try coding another solution of which the time complexity is O(n log n).
定义两个指针,st和ed。如果sum>=s,sum从前面元素开始减;如果sum< s,ed++。
   public int minSubArrayLen(int s, int[] nums) {
        int sum = 0;
        int st = 0;
        int min = Integer.MAX_VALUE;
        for (int i = 0; i < nums.length; i++) {
            sum += nums[i];
            if (sum >= s) {
                while (sum - nums[st] >= s) {
                    sum -= nums[st++];
                min = Math.min(min, i - st + 1);
        if (min > nums.length) {
            return 0;
        return min;
