Leetcode 题目解析之 Minimum Path Sum
ruochen 发表于 2022/01/14 13:48:12 2022/01/14
【摘要】 Leetcode 题目解析之 Minimum Path Sum
Given a m x n grid filled with non-negative numbers, find a path from top left to bottom right which minimizes the sum of all numbers along its path.
Note: You can only move either down or right at any point in time.
建立一个背包dpm,其中dpi表示从grid0到gridi的最小和。
    public int minPathSum(int[][] grid) {
        if (grid == null || grid[0] == null) {
            return 0;
        int m = grid.length;
        int n = grid[0].length;
        int[][] dp = new int[m][n];
        dp[0][0] = grid[0][0];
        for (int y = 1; y < n; y++) {
            dp[0][y] = dp[0][y - 1] + grid[0][y];
        for (int x = 1; x < m; x++) {
            dp[x][0] = dp[x - 1][0] + grid[x][0];
                int min = Math.min(dp[x - 1][y], dp[x][y - 1]);
                dp[x][y] = min + grid[x][y];
        return dp[m - 1][n - 1];
