Leetcode 题目解析之 Maximum Subarray
ruochen 发表于 2022/01/14 13:47:14 2022/01/14
【摘要】 Leetcode 题目解析之 Maximum Subarray
Find the contiguous subarray within an array (containing at least one number) which has the largest sum.
For example, given the array −2,1,−3,4,−1,2,1,−5,4,
the contiguous subarray 4,−1,2,1 has the largest sum = 6.
More practice:
If you have figured out the O(n) solution, try coding another solution using the divide and conquer approach, which is more subtle.
curSum存储数组当前的和,maxSum存储数组中连续最大的和。
假设数组是−2,1,−3,4,−1,2,1,−5,4,首先curSum = -2, maxSum = -2。
  1. 当i=1时,对于数组-2,1,curSum + nums1 = -1, 小于nums1 = 1。所以以后-2就可以舍弃,计算curSum时就从i=1开始。
  2. 当i=2时,对于数组-2,1,-3,curSum + nums2 = -2, 大于nums2 = -3。虽然没有比原来大,但是至少比nums2大,对于以后计算更接近最优解。
  3. 以此类推。
    public int maxSubArray(int[] nums) {
        if (nums == null || nums.length == 0) {
            return 0;
        int curSum = nums[0];
        int maxSum = nums[0];
        for (int i = 1; i < nums.length; i++) {
            curSum = Math.max(curSum + nums[i], nums[i]);
            maxSum = Math.max(curSum, maxSum);
        return maxSum;
