Leetcode 题目解析之 Majority Element
ruochen 发表于 2022/01/14 13:45:48 2022/01/14
【摘要】 Leetcode 题目解析之 Majority Element
Given an array of size n, find the majority element. The majority element is the element that appears more than ⌊ n/2 ⌋ times.
You may assume that the array is non-empty and the majority element always exist in the array.
A Linear Time Majority Vote Algorithm 一个典型的算法,可以在一次遍历,时间复杂度是O(1),空间复杂度是O(1)的情况下完成。
    public int majorityElement(int[] nums) {
        int m = nums[0];
        int c = 1;
        for (int i = 1; i < nums.length; i++) {
            if (m == nums[i]) {
                c++;
            } else if (c > 1) {
                c--;
                m = nums[i];
        return m;
