Leetcode 题目解析之 Find Minimum in Rotated Sorted Array
ruochen 发表于 2022/01/14 13:43:46 2022/01/14
【摘要】 Leetcode 题目解析之 Find Minimum in Rotated Sorted Array
Suppose a sorted array is rotated at some pivot unknown to you beforehand.
(i.e., 0 1 2 4 5 6 7 might become 4 5 6 7 0 1 2).
Find the minimum element.
You may assume no duplicate exists in the array.
数列基本有序,则使用二分查找。假设数列是n,s是起始下标,e是最后下标,m是中间元素下标。分为三种情况:
ns < ne
nm > ns > ne
nm < ne < ns
情况1:ns < ne
0 1 2 4 5 6 7
这种情况,直接返回ns。因为数列是有序的,或者只是旋转过一次。如果ns < ne,则表明没有旋转。最小元素是ns。
情况2:nm > ns > ne
4 5 6 7 0 1 2
    public int findMin(int[] nums) {
        if (nums.length == 1) {
            return nums[0];
        if (nums.length == 2) {
            return Math.min(nums[0], nums[1]);
        int s = 0, e = nums.length - 1;
        int m = (s + e) / 2;
        if (nums[s] < nums[e]) {
            return nums[s];
        if (nums[m] > nums[s]) {
            return findMin(Arrays.copyOfRange(nums, m + 1, e + 1));
        return findMin(Arrays.copyOfRange(nums, s, m + 1));
