Leetcode 题目解析之 Combination Sum III
ruochen 发表于 2022/01/14 13:41:25 2022/01/14
【摘要】 Leetcode 题目解析之 Combination Sum III
Find all possible combinations of k numbers that add up to a number n, given that only numbers from 1 to 9 can be used and each combination should be a unique set of numbers.
Ensure that numbers within the set are sorted in ascending order.
Example 1:
Input: k = 3, n = 7
Output:
[1,2,4]
Example 2:
Input: k = 3, n = 9
Output:
[1,2,6, 1,3,5, 2,3,4]
这次是指定了元素的个数,用一个变量记录即可。
    public List<List<Integer>> combinationSum3(int k, int n) {
        List<List<Integer>> rt = new ArrayList<List<Integer>>();
        if (k < 1 || n < 1) {
            return rt;
        List<Integer> cur = new ArrayList<Integer>();
        dfs(rt, cur, 0, k, n, 1);
        return rt;
    private void dfs(List<List<Integer>> rt, List<Integer> cur, int sum, int k,
            int n, int level) {
        if (sum == n && k == 0) {
            rt.add(new ArrayList<Integer>(cur));
            return;
        } else if (sum > n || k <= 0) {
            return;
        for (int i = level; i <= 9; i++) {
            cur.add(i);
            dfs(rt, cur, sum + i, k - 1, n, i + 1);
            cur.remove(cur.size() - 1);
