Leetcode 题目解析之 Combination Sum II
ruochen 发表于 2022/01/14 13:40:56 2022/01/14
【摘要】 Leetcode 题目解析之 Combination Sum II
Given a collection of candidate numbers © and a target number (T), find all unique combinations in C where the candidate numbers sums to T.
Each number in C may only be used once in the combination.
Note:
  • All numbers (including target) will be positive integers.
  • Elements in a combination (a1, a2, … , ak) must be in non-descending order. (ie, a1 ≤ a2 ≤ … ≤ ak).
  • The solution set must not contain duplicate combinations.
    For example, given candidate set 10,1,2,7,6,1,5 and target 8,
A solution set is:
1, 7
1, 2, 5
2, 6
1, 1, 6
  1. Combination Sum每个元素可以使用多次,所以递归是dfs(i, target - candidatesi, result, cur, candidates);
  2. Combination Sum II每个元素只能使用一次,所以递归是dfs(i + 1, target - candidatesi, rt, cur, candidates);因为解可能重复,所以使用set,最后转成list。
    public List<List<Integer>> combinationSum2(int[] candidates, int target) {
        if (candidates == null || candidates.length == 0) {
            return new ArrayList<List<Integer>>();
        Set<List<Integer>> rt = new HashSet<List<Integer>>();
        ArrayList<Integer> cur = new ArrayList<Integer>();
        Arrays.sort(candidates);
        dfs(0, target, rt, cur, candidates);
        return new ArrayList<List<Integer>>(rt);
    private void dfs(int start, int target, Set<List<Integer>> rt,
            ArrayList<Integer> cur, int[] candidates) {
        if (target == 0) {
            rt.add(new ArrayList<Integer>(cur));
            return;
        for (int i = start; i < candidates.length; i++) {
            // candidates[i] > target,则递归结束,后面不可能是解
            if (candidates[i] > target) {
                return;
            cur.add(candidates[i]);
            dfs(i + 1, target - candidates[i], rt, cur, candidates);
            cur.remove(cur.size() - 1);
