Leetcode 题目解析之 Combination Sum
ruochen 发表于 2022/01/14 13:40:04 2022/01/14
【摘要】 Leetcode 题目解析之 Combination Sum
Given a set of candidate numbers © and a target number (T), find all unique combinations in C where the candidate numbers sums to T.
The same repeated number may be chosen from C unlimited number of times.
Note:
  • All numbers (including target) will be positive integers.
  • Elements in a combination (a1, a2, … , ak) must be in non-descending order. (ie, a1 ≤ a2 ≤ … ≤ ak).
  • The solution set must not contain duplicate combinations.
For example, given candidate set 2,3,6,7 and target 7,
A solution set is:
7
2, 2, 3
使用递归,注意保存结果时,应该新建一个ArrayList:result.add(new ArrayList< Integer>(cur))。否则result会指向一直变化的cur。
    public List<List<Integer>> combinationSum(int[] candidates, int target) {
        if (candidates == null || candidates.length == 0) {
            return new ArrayList<List<Integer>>();
        List<List<Integer>> result = new ArrayList<List<Integer>>();
        ArrayList<Integer> cur = new ArrayList<Integer>();
        Arrays.sort(candidates);
        dfs(0, target, result, cur, candidates);
        return result;
    private void dfs(int start, int target, List<List<Integer>> result,
            ArrayList<Integer> cur, int[] candidates) {
        if (target == 0) {
            result.add(new ArrayList<Integer>(cur));
            return;
        for (int i = start; i < candidates.length; i++) {
            // candidates[i] > target,则递归结束,后面不可能是解
            if (candidates[i] > target) {
                return;
            cur.add(candidates[i]);
            dfs(i, target - candidates[i], result, cur, candidates);
            cur.remove(cur.size() - 1);
