Leetcode 题目解析之 3Sum
ruochen 发表于 2022/01/14 13:36:32 2022/01/14
【摘要】 Leetcode 题目解析之 3Sum
Given an array S of n integers, are there elements a, b, c in S such that a + b + c = 0? Find all unique triplets in the array which gives the sum of zero.
Note:
  • Elements in a triplet (a,b,c) must be in non-descending order. (ie, a ≤ b ≤ c)
  • The solution set must not contain duplicate triplets.```
    For example, given array S = {-1 0 1 2 -1 -4},
    A solution set is:
    (-1, 0, 1)
    (-1, -1, 2)
对数组进行排序;
start从0到n-1,对numstart求另外两个数,这里用mid和end;
mid指向start+1,q指向结尾。sum = numstart + nummid+ numend;
利用加逼定理求解,终止条件是mid == end;
顺带去重
去重:
如果start到了start+1,numstart == numstart - 1,则求出的解肯定重复了;
如果mid++,nummid = nummid - 1,则求出的解肯定重复了。
public List<List<Integer>> threeSum(int[] nums) {
    if (nums == null || nums.length < 3) {
        return new ArrayList<List<Integer>>();
    Set<List<Integer>> set = new HashSet<List<Integer>>();
    Arrays.sort(nums);
    for (int start = 0; start < nums.length; start++) {
        if (start != 0 && nums[start - 1] == nums[start]) {
            continue;
        int mid = start + 1, end = nums.length - 1;
        while (mid < end) {
            int sum = nums[start] + nums[mid] + nums[end];
            if (sum == 0) {
                List<Integer> tmp = new ArrayList<Integer>();
                tmp.add(nums[start]);
                tmp.add(nums[mid]);
                tmp.add(nums[end]);
                set.add(tmp);
                while (++mid < end && nums[mid - 1] == nums[mid])
                while (--end > mid && nums[end + 1] == nums[end])
            else if (sum < 0) {
                mid++;
            else {
                end--;
    return new ArrayList<List<Integer>>(set);
