Leetcode 题目解析之 3Sum Closest
ruochen 发表于 2022/01/14 13:36:05 2022/01/14
【摘要】 Leetcode 题目解析之 3Sum Closest
Given an array S of n integers, find three integers in S such that the sum is closest to a given number, target. Return the sum of the three integers. You may assume that each input would have exactly one solution.
For example, given array S = {-1 2 1 -4}, and target = 1.
The sum that is closest to the target is 2. (-1 + 2 + 1 = 2).
    public int threeSumClosest(int[] nums, int target) {
        if (nums == null || nums.length < 3) {
            return Integer.MIN_VALUE;
        Arrays.sort(nums);
        int minGap = Integer.MAX_VALUE;
        int result = 0;
        for (int start = 0; start < nums.length; start++) {
            int mid = start + 1, end = nums.length - 1;
            while (mid < end) {
                int sum = nums[start] + nums[mid] + nums[end];
                int gap = Math.abs(sum - target);
                if (gap < minGap) {
                    minGap = gap;
                    result = sum;
                if (sum < target) {
                    mid++;
                    end--;
        return result;
