Android O中修改NotificationChannel 属性,升级app后该修改不生效,必须卸载app重新安装才能生效
程思扬 发表于 2022/01/14 00:50:31 2022/01/14
【摘要】 ndroid 8.0中修改NotificationChannel 属性,升级app后该修改不生效,必须卸载app重新安装才能生效,原代码如下: public void notifyDownloading(long progress, long num, String file_name) { Notification.Build...
  1. public void notifyDownloading(long progress, long num, String file_name) {
  2. Notification.Builder mBuilder;
  3. mBuilder = new Notification.Builder(MainActivity.this, TAG );
  4. NotificationChannel channel;
  5. channel = new NotificationChannel(TAG , file_name, NotificationManager.IMPORTANCE_LOW);
  6. mNotifyManager.createNotificationChannel(channel);
  7. mBuilder.setSmallIcon(R.drawable.notification_download_icon);
  8. mBuilder.setProgress((int) num, (int) progress, false);
  9. mBuilder.setContentInfo(getPercent((int) progress, (int) num));
  10. mBuilder.setOngoing(true);
  11. mBuilder.setWhen(System.currentTimeMillis());
  12. mBuilder.setContentTitle(file_name);
  13. mBuilder.setContentText("download");
  14. PendingIntent pendIntent = PendingIntent.getActivity(
  15. MainActivity.this, NOTIFY_ID, getCurActivityIntent(), PendingIntent.FLAG_UPDATE_CURRENT);
  16. mBuilder.setContentIntent(pendIntent);
  17. mNotifyManager.notify(NOTIFY_ID, mBuilder.build());
  18. }
这里将IMPORTANCE_HIGH修改为IMPORTANCE_LOW,通过Android Studio直接安装,发现修改不生效,app的效果还是IMPORTANCE_HIGH属性的效果。总之,一脸懵逼。。。
经过若干猜测和尝试,发现修改每次创建Notification.Builder的id和NotificationChannel的id就可以规避该问题,修改后代码如下:
  3. mBuilder = new Notification.Builder(MainActivity.this, TAG + System.currentTimeMillis());
  5. channel = new NotificationChannel(TAG + System.currentTimeMillis(), file_name, NotificationManager.IMPORTANCE_LOW);
  18. }
通过System.currentTimeMillis()保证每次创建对象的Id不同。
文章来源: chengsy.blog.csdn.net,作者:程思扬,版权归原作者所有,如需转载,请联系作者。
原文链接:chengsy.blog.csdn.net/article/details/80449108
