Android 中Notification进度条一直弹出提示及提示音
程思扬 发表于 2022/01/14 00:54:54 2022/01/14
【摘要】 Android 8.0中Notification的Progress每次更新进度,都会弹出提示,并且有提示音。原代码如下 public void notifyDownloading(long progress, long num, String file_name) { Notification.Builder mBuilder;...
    mBuilder = new Notification.Builder(MainActivity.this, TAG);
    NotificationChannel channel;
    channel = new NotificationChannel(TAG , file_name, NotificationManager.IMPORTANCE_MAX);
    mNotifyManager.createNotificationChannel(channel);
    mBuilder.setSmallIcon(R.drawable.notification_download_icon);
    mBuilder.setProgress((int) num, (int) progress, false);
    mBuilder.setContentInfo(getPercent((int) progress, (int) num));
    mBuilder.setOngoing(true);
    mBuilder.setWhen(System.currentTimeMillis());
    mBuilder.setContentTitle(file_name);
    mBuilder.setContentText("download");
    PendingIntent pendIntent = PendingIntent.getActivity(
            MainActivity.this, NOTIFY_ID, getCurActivityIntent(), PendingIntent.FLAG_UPDATE_CURRENT);
    mBuilder.setContentIntent(pendIntent);
    mNotifyManager.notify(NOTIFY_ID, mBuilder.build());
这里需要修改NotificationChannel的importance属性:
 * Min notification importance: only shows in the shade, below the fold.
public static final int IMPORTANCE_MIN = 1;
 * Low notification importance: shows everywhere, but is not intrusive.
public static final int IMPORTANCE_LOW = 2;
 * Default notification importance: shows everywhere, makes noise, but does not visually
 * intrude.
public static final int IMPORTANCE_DEFAULT = 3;
 * Higher notification importance: shows everywhere, makes noise and peeks. May use full screen
 * intents.
public static final int IMPORTANCE_HIGH = 4;
 * Unused.
public static final int IMPORTANCE_MAX = 5;
这里的IMPORTANCE_MAX应该和IMPORTANCE_HIGH属性类似,表示显示时有声音,且会出现弹框提示。在Android 8.0中,这样设置后,Progress每次更新都会有声音和弹框。
把IMPORTANCE_MAX修改为IMPORTANCE_LOW,则不会出现该现象。
修改后代码如下:
    mBuilder = new Notification.Builder(MainActivity.this, TAG );
    channel = new NotificationChannel(TAG, file_name, NotificationManager.IMPORTANCE_LOW);
文章来源: chengsy.blog.csdn.net,作者:程思扬,版权归原作者所有,如需转载,请联系作者。
原文链接:chengsy.blog.csdn.net/article/details/80448313
