Android 获取系统时间及时间戳转换
程思扬 发表于 2022/01/13 22:35:34 2022/01/13
【摘要】 //获取当前时间戳long timeStamp = System.currentTimeMillis();String time = stampToDate(timeStamp);Log.d("xxxxx", time); //获取当前时间Calendar c = Calendar.getInstance();//可以对每个时间域单独修...
  1. //获取当前时间戳
  2. long timeStamp = System.currentTimeMillis();
  3. String time = stampToDate(timeStamp);
  4. Log.d("xxxxx", time);
  1. //获取当前时间
  2. Calendar c = Calendar.getInstance();//可以对每个时间域单独修改
  3. int year = c.get(Calendar.YEAR);
  4. int month = c.get(Calendar.MONTH);
  5. int date = c.get(Calendar.DATE);
  6. int hour = c.get(Calendar.HOUR_OF_DAY);
  7. int minute = c.get(Calendar.MINUTE);
  8. int second = c.get(Calendar.SECOND);
  9. Log.d("xxxxx",year + "/" + (month+1) + "/" + date + " " +hour + ":" +minute + ":" + second);
  1. /*
  2. * 将时间转换为时间戳
  3. */
  4. public String dateToStamp(String time) throws ParseException {
  5. SimpleDateFormat simpleDateFormat = new SimpleDateFormat("yyyy-MM-dd HH:mm:ss");
  6. Date date = simpleDateFormat.parse(time);
  7. long ts = date.getTime();
  8. return String.valueOf(ts);
  9. }
  10. /*
  11. * 将时间戳转换为时间
  12. */
  13. public String stampToDate(long timeMillis){
  14. SimpleDateFormat simpleDateFormat = new SimpleDateFormat("yyyy-MM-dd HH:mm:ss");
  15. Date date = new Date(timeMillis);
  16. return simpleDateFormat.format(date);
  17. }
文章来源: chengsy.blog.csdn.net,作者:程思扬,版权归原作者所有,如需转载,请联系作者。
原文链接:chengsy.blog.csdn.net/article/details/80677468
