Android开发禁用通知栏下拉
程思扬 发表于 2022/01/14 00:56:15 2022/01/14
【摘要】 应用禁用通知栏下拉这个需求让我头疼了好几天 statusbar用了后但是效果不是很满意 其他的方法试过但是没有效果,所以就换个思路吧 做法是在通知栏区域弄一个透明的window,这样下拉的时候触摸的区域就...
做法是在通知栏区域弄一个透明的window,这样下拉的时候触摸的区域就是这个window,系统的就下拉不了了
该做法是需要在应用上方显示一个window 所以需要权限
 <uses-permission android:name="android.permission.SYSTEM_ALERT_WINDOW" />
 public static final String STATUS_BAR_HEIGHT = "status_bar_height";
  public static final String DIMEN = "dimen";
  public static final String DEF_PACKAGE = "android";
   public static void preventStatusBarExpansion(Context context) {
    WindowManager manager = ((WindowManager) context.getApplicationContext()
                                                    .getSystemService(Context.WINDOW_SERVICE));
    WindowManager.LayoutParams localLayoutParams = new WindowManager.LayoutParams();
    localLayoutParams.type = WindowManager.LayoutParams.TYPE_SYSTEM_ERROR;
    localLayoutParams.gravity = Gravity.TOP;
    localLayoutParams.flags = WindowManager.LayoutParams.FLAG_NOT_FOCUSABLE
        | WindowManager.LayoutParams.FLAG_NOT_TOUCH_MODAL
        | WindowManager.LayoutParams.FLAG_LAYOUT_IN_SCREEN;
    localLayoutParams.width = WindowManager.LayoutParams.MATCH_PARENT;
    int resId = context.getResources()
                       .getIdentifier(STATUS_BAR_HEIGHT, DIMEN, DEF_PACKAGE);
    int result;
    if (resId > 0) {
      result = context.getResources()
                      .getDimensionPixelSize(resId);
      // Use Fallback size:
      result = 60; // 60px Fallback
    localLayoutParams.height = result;
    localLayoutParams.format = PixelFormat.TRANSPARENT;
    if (view == null) {
      view = new CustomViewGroup(context);
    try {
      if (manager != null) {
        manager.addView(view, localLayoutParams);
    } catch (Exception ignored) {
  public static void allowStatusBarExpansion(Context context) {
    try {
        manager.removeViewImmediate(view);
  public static class CustomViewGroup extends ViewGroup {
    public CustomViewGroup(Context context) {
      super(context);
    @Override
    protected void onLayout(boolean changed,
                            int l,
                            int t,
                            int r,
                            int b) {
    @Override
    public boolean onInterceptTouchEvent(MotionEvent ev) {
      // Intercepted touch!
      return true;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
文章来源: chengsy.blog.csdn.net,作者:程思扬,版权归原作者所有,如需转载,请联系作者。
原文链接:chengsy.blog.csdn.net/article/details/106222568
