如何解决Android 5.0中出现的警告:Service Intent must be explicit
再见孙悟空_ 发表于 2022/01/14 00:50:20 2022/01/14
【摘要】 有些时候我们使用Service的时需要采用隐私启动的方式,但是Android 5.0一出来后,其中有个特性就是Service Intent  must be explitict,也就是说从Lollipop开始,service服务必须采用显示方式启动。而android源码是这样写的(源码位置:sdk/sources/a...
而android源码是这样写的(源码位置:sdk/sources/android-21/android/app/ContextImpl.java):
  1. private void validateServiceIntent(Intent service) {
  2.         if (service.getComponent() == null && service.getPackage() == null) {
  3.             if (getApplicationInfo().targetSdkVersion >= Build.VERSION_CODES.LOLLIPOP) {
  4.                 IllegalArgumentException ex = new IllegalArgumentException(
  5.                         "Service Intent must be explicit: " + service);
  6.                 throw ex;
  7.             } else {
  8.                 Log.w(TAG, "Implicit intents with startService are not safe: " + service
  9.                         + " " + Debug.getCallers(2, 3));
  10.             }
  11.         }
  12.     }
复制代码
既然,源码里是这样写的,那么这里有两种解决方法:
1、设置Action和packageName:
参考代码如下:
  1. Intent mIntent = new Intent();
  2. mIntent.setAction("XXX.XXX.XXX");//你定义的service的action
  3. mIntent.setPackage(getPackageName());//这里你需要设置你应用的包名
  4. context.startService(mIntent);
复制代码
此方式是google官方推荐使用的解决方法。
在此附上地址供大家参考:http://developer.android.com/goo ... tml#billing-service,有兴趣的可以去看看。
2、将隐式启动转换为显示启动:--参考地址:Google In-App billing, IllegalArgumentException: Service Intent must be explicit, after upgrading to Android L Dev Preview - Stack Overflow
  1. public static Intent getExplicitIntent(Context context, Intent implicitIntent) {
  2.         // Retrieve all services that can match the given intent
  3.         PackageManager pm = context.getPackageManager();
  4.         List<ResolveInfo> resolveInfo = pm.queryIntentServices(implicitIntent, 0);
  5.         // Make sure only one match was found
  6.         if (resolveInfo == null || resolveInfo.size() != 1) {
  7.             return null;
  8.         }
  9.         // Get component info and create ComponentName
  10.         ResolveInfo serviceInfo = resolveInfo.get(0);
  11.         String packageName = serviceInfo.serviceInfo.packageName;
  12.         String className = serviceInfo.serviceInfo.name;
  13.         ComponentName component = new ComponentName(packageName, className);
  14.         // Create a new intent. Use the old one for extras and such reuse
  15.         Intent explicitIntent = new Intent(implicitIntent);
  16.         // Set the component to be explicit
  17.         explicitIntent.setComponent(component);
  18.         return explicitIntent;
  19.     }
复制代码
调用方式如下:
  3. Intent eintent = new Intent(getExplicitIntent(mContext,mIntent));
  4. context.startService(eintent);
复制代码
文章来源: wukong.blog.csdn.net,作者:再见孙悟空_,版权归原作者所有,如需转载,请联系作者。
原文链接:wukong.blog.csdn.net/article/details/52371380
