android sqlite 判断表和表中字段是否存在方法
再见孙悟空_ 发表于 2022/01/14 00:28:46 2022/01/14
【摘要】 /** *检查某表是否存在 * @param tableName 表名 * @return true:存在 false:不存在 */ public boolean tabIsExist(String tabName){ boolean result = false; if(t...
          *检查某表是否存在
             if(tabName == null){
                     return false;
             Cursor cursor = null;
             try {
                     String sql = "select count(*) as c from sqlite_master where type ='table' and name ='"+tabName.trim()+"' ";
                      cursor = mUDB.rawQuery(sql, null);
                     if(cursor.moveToNext()){
                             int count = cursor.getInt(0);
                             if(count>0){
                                      result = true;
              } catch (Exception e) {
             return result;
       *检查表中某列是否存在
       * @param db
       * @param columnName 列名
         private boolean checkColumnExists2(SQLiteDatabase db, String tableName , String columnName) {
             boolean result = false ;
             Cursor cursor = null ;
             try{
                  cursor = db.rawQuery( "select * from sqlite_master where name = ? and sql like ?"
                     , new String[]{tableName , "%" + columnName + "%"} );
                  result = null != cursor && cursor.moveToFirst() ;
              }catch (Exception e){
                  Log.e("","checkColumnExists2..." + e.getMessage()) ;
              }finally{
                 if(null != cursor && !cursor.isClosed()){
                      cursor.close() ;
             return result ;
文章来源: wukong.blog.csdn.net,作者:再见孙悟空_,版权归原作者所有,如需转载,请联系作者。
原文链接:wukong.blog.csdn.net/article/details/72764845
评论(0
