addHeaderView()异常 —— setAdapter has already been called
再见孙悟空_ 发表于 2022/01/12 23:27:45 2022/01/12
【摘要】 异常提示:java.lang.IllegalStateException: Cannot add header view to list -- setAdapter has already been called. ...
产生原因:addHeaderView()调用在setAdapter()之后,并且该代码运行在Android4.3之前的系统版本。Android SDK与API Level对应表
我们来看看(Android4.3)API-18 和 (Android4.2)API-17的Listview代码片段:
API-18
[java]  view plain copy print ?
  1. public void addHeaderView(View v, Object data, boolean isSelectable) {
  2.         final FixedViewInfo info = new FixedViewInfo();
  3.         info.view = v;
  4.         info.data = data;
  5.         info.isSelectable = isSelectable;
  6.         mHeaderViewInfos.add(info);
  7.
  8.         // Wrap the adapter if it wasn't already wrapped.
  9.         if (mAdapter != null) {
  10.             if (!(mAdapter instanceof HeaderViewListAdapter)) {
  11.                 mAdapter = new HeaderViewListAdapter(mHeaderViewInfos, mFooterViewInfos, mAdapter);
  12.             }
  13.
  14.             // In the case of re-adding a header view, or adding one later on,
  15.             // we need to notify the observer.
  16.             if (mDataSetObserver != null) {
  17.                 mDataSetObserver.onChanged();
  18.             }
  19.         }
  20. }
API-17
  2.
  3.         if (mAdapter != null && ! (mAdapter instanceof HeaderViewListAdapter)) {
  4.             throw new IllegalStateException(
  5.                     "Cannot add header view to list -- setAdapter has already been called.");
  6.         }
  7.
  8.         FixedViewInfo info = new FixedViewInfo();
  9.         info.view = v;
  10.         info.data = data;
  11.         info.isSelectable = isSelectable;
  12.         mHeaderViewInfos.add(info);
  13.
  14.         // in the case of re-adding a header view, or adding one later on,
  16.         if (mAdapter != null && mDataSetObserver != null) {
  18.         }
  19. }
在API-17中,假如adapter不为空,则会直接抛出异常,而在API-18中则做了相关的优化。
建议
木有建设性的提议,只能提醒大家,目前市面上主流的Android系统还是Android4.3以下版本,所以在使用addHeaderView()要注意这一点。
文章来源: wukong.blog.csdn.net,作者:再见孙悟空_,版权归原作者所有,如需转载,请联系作者。
原文链接:wukong.blog.csdn.net/article/details/50385912
