hive metastore配置kerberos认证
从大数据到人工智能 发表于 2022/01/12 20:02:51 2022/01/12
【摘要】 hive从3.0.0开始提供hive metastore单独服务作为像presto、flink、spark等组件的元数据中心。但是默认情况下hive metastore在启动之后是不需要进行认证就可以访问的。所以本文基于大数据组件中流行的kerberos认证方式,对hive metastore进行认证配置。如果您还不了解如何单独启用hive metastore服务,那么您可以参考下述文章。P...
Presto使用Docker独立运行Hive Standalone Metastore管理MinIO(S3)
kdc安装
已知安装kdc的主机的hostname为:hadoop
yum install -y krb5-server krb5-libs krb5-auth-dialog krb5-workstation
修改配置文件
修改/var/kerberos/krb5kdc/kdc.conf,默认内容为
[kdcdefaults]
 kdc_ports = 88
 kdc_tcp_ports = 88
[realms]
 EXAMPLE.COM = {
  #master_key_type = aes256-cts
  acl_file = /var/kerberos/krb5kdc/kadm5.acl
  dict_file = /usr/share/dict/words
  admin_keytab = /var/kerberos/krb5kdc/kadm5.keytab
  supported_enctypes = aes256-cts:normal aes128-cts:normal des3-hmac-sha1:normal arcfour-hmac:normal camellia256-cts:normal camellia128-cts:normal des-hmac-sha1:normal des-cbc-md5:normal des-cbc-crc:normal
可修改EXAMPLE.COM为您自己设定的域,例如本文将此设置为BIGDATATOAI.COM
[kdcdefaults]
 kdc_ports = 88
 kdc_tcp_ports = 88
[realms]
 BIGDATATOAI.COM = {
修改/etc/krb5.conf,默认文件为
# Configuration snippets may be placed in this directory as well
includedir /etc/krb5.conf.d/
[logging]
 default = FILE:/var/log/krb5libs.log
 kdc = FILE:/var/log/krb5kdc.log
 admin_server = FILE:/var/log/kadmind.log
[libdefaults]
 dns_lookup_realm = false
 ticket_lifetime = 24h
 renew_lifetime = 7d
 forwardable = true
 rdns = false
 pkinit_anchors = FILE:/etc/pki/tls/certs/ca-bundle.crt
# default_realm = EXAMPLE.COM
 default_ccache_name = KEYRING:persistent:%{uid}
[realms]
# EXAMPLE.COM = {
#  kdc = kerberos.example.com
#  admin_server = kerberos.example.com
[domain_realm]
# .example.com = EXAMPLE.COM
# example.com = EXAMPLE.COM
修改为如下所示,其中,将域设置为BIGDATATOAI.COM,kdc和admin_server设置为hadoop
[logging]
[libdefaults]
 renew_lifetime = 7d
 forwardable = true
 rdns = false
 default_realm = BIGDATATOAI.COM
[realms]
BIGDATATOAI.COM = {
  kdc = hadoop
  admin_server = hadoop
[domain_realm]
初始化kerberos数据库
kdb5_util create -s -r BIGDATATOAI.COM
初始化过程中会要求重复输入kdc数据库的master key,请输入该master key。
[root@hadoop data]# kdb5_util create -s -r BIGDATATOAI.COM
Loading random data
Initializing database '/var/kerberos/krb5kdc/principal' for realm 'BIGDATATOAI.COM',
master key name 'K/M@BIGDATATOAI.COM'
You will be prompted for the database Master Password.
It is important that you NOT FORGET this password.
Enter KDC database master key:
Re-enter KDC database master key to verify:
添加管理员用户
kadmin.local
在添加过程中会要求重复输入用户的密码,请输入该密码两次即可。
[root@hadoop data]# kadmin.local
Authenticating as principal root/admin@BIGDATATOAI.COM with password.
kadmin.local:  addprinc admin/admin@BIGDATATOAI.COM
WARNING: no policy specified for admin/admin@BIGDATATOAI.COM; defaulting to no policy
Enter password for principal "admin/admin@BIGDATATOAI.COM":
Re-enter password for principal "admin/admin@BIGDATATOAI.COM":
Principal "admin/admin@BIGDATATOAI.COM" created.
修改/var/kerberos/krb5kdc/kadm5.acl,设置为
*/admin@BIGDATATOAI.COM *
启动相关服务
systemctl start krb5kdc
systemctl start kadmin
使用管理员用户添加principal
kadmin -p admin/admin
进入kadmin客户端之后,添加hive-metastore/hadoop@BIGDATATOAI.COM这个principal。在添加过程中会要求重复输入用户的密码,请输入该密码两次即可。
[root@hadoop data]# kadmin -p admin/admin
Authenticating as principal admin/admin with password.
Password for admin/admin@BIGDATATOAI.COM:
kadmin:  add_principal hive-metastore/hadoop
WARNING: no policy specified for hive-metastore/hadoop@BIGDATATOAI.COM; defaulting to no policy
Enter password for principal "hive-metastore/hadoop@BIGDATATOAI.COM":
Re-enter password for principal "hive-metastore/hadoop@BIGDATATOAI.COM":
Principal "hive-metastore/hadoop@BIGDATATOAI.COM" created.
导出principal
kadmin:  xst -t /root/hive-metastore.keytab -norandkey hive-metastore/hadoop
kadmin: Principal -t does not exist.
kadmin: Principal /root/hive-metastore.keytab does not exist.
kadmin: Principal -norandkey does not exist.
Entry for principal hive-metastore/hadoop with kvno 2, encryption type aes256-cts-hmac-sha1-96 added to keytab FILE:/etc/krb5.keytab.
Entry for principal hive-metastore/hadoop with kvno 2, encryption type aes128-cts-hmac-sha1-96 added to keytab FILE:/etc/krb5.keytab.
Entry for principal hive-metastore/hadoop with kvno 2, encryption type des3-cbc-sha1 added to keytab FILE:/etc/krb5.keytab.
Entry for principal hive-metastore/hadoop with kvno 2, encryption type arcfour-hmac added to keytab FILE:/etc/krb5.keytab.
Entry for principal hive-metastore/hadoop with kvno 2, encryption type camellia256-cts-cmac added to keytab FILE:/etc/krb5.keytab.
Entry for principal hive-metastore/hadoop with kvno 2, encryption type camellia128-cts-cmac added to keytab FILE:/etc/krb5.keytab.
Entry for principal hive-metastore/hadoop with kvno 2, encryption type des-hmac-sha1 added to keytab FILE:/etc/krb5.keytab.
Entry for principal hive-metastore/hadoop with kvno 2, encryption type des-cbc-md5 added to keytab FILE:/etc/krb5.keytab.
修改metastore-site.xml
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?xml-stylesheet type="text/xsl" href="configuration.xsl"?>
<configuration>
    <property>
        <name>javax.jdo.option.ConnectionURL</name>
        <value>jdbc:mysql://192.168.1.3:3306/metastore_2?useSSL=false&serverTimezone=UTC</value>
    </property>
    <property>
        <name>javax.jdo.option.ConnectionDriverName</name>
        <value>com.mysql.jdbc.Driver</value>
    </property>
    <property>
        <name>javax.jdo.option.ConnectionUserName</name>
        <value>root</value>
    </property>
    <property>
        <name>javax.jdo.option.ConnectionPassword</name>
        <value>password</value>
    </property>
    <property>
        <name>hive.metastore.event.db.notification.api.auth</name>
        <value>false</value>
    </property>
    <property>
        <name>metastore.thrift.uris</name>
        <value>thrift://localhost:9083</value>
        <description>Thrift URI for the remote metastore. Used by metastore client to connect to remote metastore.</description>
    </property>
    <property>
        <name>metastore.task.threads.always</name>
        <value>org.apache.hadoop.hive.metastore.events.EventCleanerTask</value>
    </property>
    <property>
        <name>metastore.expression.proxy</name>
        <value>org.apache.hadoop.hive.metastore.DefaultPartitionExpressionProxy</value>
    </property>
    <property>
        <name>metastore.warehouse.dir</name>
        <value>files:///user/hive/warehouse</value>
    </property>
    <property>
        <name>hive.metastore.authentication.type</name>
        <value>kerberos</value>
    </property>
    <property>
        <name>hive.metastore.thrift.impersonation.enabled</name>
        <value>true</value>
    </property>
    <property>
        <name>hive.metastore.kerberos.principal</name>
        <value>hive-metastore/hadoop@BIGDATATOAI.COM</value>
    </property>
    <property>
        <name>hive.metastore.sasl.enabled</name>
        <value>true</value>
    </property>
    <property>
        <name>hive.metastore.kerberos.keytab.file</name>
        <value>/etc/hive/conf/hive-metastore.keytab</value>
    </property>
</configuration>
由于hive-metastore的kerberos服务依赖于hdfs组件,所以还需要在core-site.xml中新增如下配置:
  <property>
    <name>hadoop.proxyuser.hive-metastore.groups</name>
    <value>*</value>
  </property>
  <property>
    <name>hadoop.proxyuser.hive-metastore.hosts</name>
    <value>*</value>
  </property>
<property>
  <name>hadoop.security.authorization</name>
  <value>true</value>
</property>
<property>
  <name>hadoop.security.auth_to_local</name>
  <value>
  RULE:[2:$1@$0](hive-metastore/.*@.*BIGDATATOAI.COM)s/.*/hive-metastore/
  DEFAULT
  </value>
</property>
<property>
  <name>hadoop.security.authentication</name>
</property>
接下来便可以启动hive metastore
bin/start-metastore
此时直接通过Java API对该HIve Metastore进行访问,如何通过Java API对HIve Metastore进行访问可参考:通过Java API获取Hive Metastore中的元数据信息
package com.zh.ch.bigdata.hms;
import org.apache.hadoop.conf.Configuration;
import org.apache.hadoop.hive.metastore.IMetaStoreClient;
import org.apache.hadoop.hive.metastore.RetryingMetaStoreClient;
import org.apache.hadoop.hive.metastore.api.MetaException;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class HMSClient {
    public static final Logger LOGGER = LoggerFactory.getLogger(HMSClient.class);
     * 初始化HMS连接
     * @param conf org.apache.hadoop.conf.Configuration
     * @return IMetaStoreClient
     * @throws MetaException 异常
    public static IMetaStoreClient init(Configuration conf) throws MetaException {
        try {
            return RetryingMetaStoreClient.getProxy(conf, false);
        } catch (MetaException e) {
            LOGGER.error("hms连接失败", e);
            throw e;
    public static void main(String[] args) throws Exception {
        Configuration conf = new Configuration();
        conf.set("hive.metastore.uris", "thrift://192.168.241.134:9083");
        // conf.addResource("hive-site.xml");
        IMetaStoreClient client = HMSClient.init(conf);
        System.out.println("----------------------------获取所有catalogs-------------------------------------");
        client.getCatalogs().forEach(System.out::println);
        System.out.println("------------------------获取catalog为hive的描述信息--------------------------------");
        System.out.println(client.getCatalog("hive").toString());
        System.out.println("--------------------获取catalog为hive的所有database-------------------------------");
        client.getAllDatabases("hive").forEach(System.out::println);
得到结果
可见如果不通过kerberos认证的话,是无法访问hive metastore的。
