分布式专题——Spring Boot JDBC
小白弟弟 发表于 2022/01/11 22:29:56 2022/01/11
【摘要】 1、Spring Boot JDBC 1.1、pom <?xml version="1.0" encoding="UTF-8"?> <project xmlns="http://ma...
1、Spring Boot JDBC
1.1、pom
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 https://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <parent>
        <artifactId>spring-boot-starter-parent</artifactId>
        <version>2.1.2.RELEASE</version>
        <relativePath/> <!-- lookup parent from repository -->
    </parent>
    <groupId>com.zhz</groupId>
    <artifactId>spring-boot-jdbc-demo</artifactId>
    <version>0.0.1-SNAPSHOT</version>
    <name>spring-boot-jdbc-demo</name>
    <description>spring-boot-jdbc的使用</description>
    <properties>
        <java.version>1.8</java.version>
    </properties>
    <dependencies>
        <dependency>
            <artifactId>spring-boot-starter-jdbc</artifactId>
        </dependency>
        <dependency>
            <groupId>mysql</groupId>
            <artifactId>mysql-connector-java</artifactId>
        </dependency>
        <dependency>
            <groupId>com.h2database</groupId>
            <artifactId>h2</artifactId>
            <scope>runtime</scope>
        </dependency>
        <dependency>
            <groupId>org.projectlombok</groupId>
            <artifactId>lombok</artifactId>
            <optional>true</optional>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-test</artifactId>
            <scope>test</scope>
        </dependency>
    </dependencies>
    <build>
        <plugins>
            <plugin>
                <artifactId>spring-boot-maven-plugin</artifactId>
            </plugin>
        </plugins>
    </build>
</project>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
1.2、yml
spring:
  datasource:
    url: jdbc:mysql://119.29.36.141:3306/guli?serverTimezone=GMT%2B8
    username: root
    password: root
    hikari:
      connection-test-query: SELECT 1
      connection-timeout: 60000
      idle-timeout: 500000
      max-lifetime: 540000
      maximum-pool-size: 12
      minimum-idle: 10
      pool-name: GuliHikariPool
    type: com.mysql.cj.jdbc.MysqlDataSource
  output:
    ansi:
      enabled: always
management:
  endpoints:
    web:
      exposure:
        include: '*'
1.3、类
package com.zhz.springbootjdbcdemo.pojo;
import lombok.Builder;
import lombok.Data;
 * @author mac
@Data
@Builder
public class Foo {
    private Long id;
    private String bar;
package com.zhz.springbootjdbcdemo.dao;
import com.zhz.springbootjdbcdemo.pojo.Foo;
import lombok.extern.slf4j.Slf4j;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.jdbc.core.JdbcTemplate;
import org.springframework.jdbc.core.RowMapper;
import org.springframework.jdbc.core.simple.SimpleJdbcInsert;
import org.springframework.stereotype.Repository;
import java.sql.ResultSet;
import java.sql.SQLException;
import java.util.Arrays;
import java.util.HashMap;
import java.util.List;
import java.util.Map;
 * @author zhouhengzhe
 * @Description: TODO
 * @date 2021/8/16下午5:09
@Slf4j
@Repository
public class FooDao {
    @Autowired
    private JdbcTemplate jdbcTemplate;
    @Autowired
    private SimpleJdbcInsert simpleJdbcInsert;
    public void insertData() {
        Arrays.asList("b", "c").forEach(bar -> {
            jdbcTemplate.update("INSERT INTO FOO (BAR) VALUES (?)", bar);
        HashMap<String, String> row = new HashMap<>();
        row.put("BAR", "d");
        Number id = simpleJdbcInsert.executeAndReturnKey(row);
        log.info("ID of d: {}", id.longValue());
    public void listData() {
        log.info("Count: {}",
                jdbcTemplate.queryForObject("SELECT COUNT(*) FROM FOO", Long.class));
        List<String> list = jdbcTemplate.queryForList("SELECT BAR FROM FOO", String.class);
        list.forEach(s -> log.info("Bar: {}", s));
        List<Foo> fooList = jdbcTemplate.query("SELECT * FROM FOO", new RowMapper<Foo>() {
            @Override
            public Foo mapRow(ResultSet rs, int rowNum) throws SQLException {
                return Foo.builder()
                        .id(rs.getLong(1))
                        .bar(rs.getString(2))
                        .build();
        fooList.forEach(f -> log.info("Foo: {}", f));
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
import org.springframework.jdbc.core.BatchPreparedStatementSetter;
import org.springframework.jdbc.core.namedparam.NamedParameterJdbcTemplate;
import org.springframework.jdbc.core.namedparam.SqlParameterSourceUtils;
import java.sql.PreparedStatement;
import java.util.ArrayList;
@Repository
public class BatchFooDao {
    @Autowired
    @Autowired
    private NamedParameterJdbcTemplate namedParameterJdbcTemplate;
    public void batchInsert() {
        jdbcTemplate.batchUpdate("INSERT INTO FOO (BAR) VALUES (?)",
                new BatchPreparedStatementSetter() {
                    @Override
                    public void setValues(PreparedStatement ps, int i) throws SQLException {
                        ps.setString(1, "b-" + i);
                    @Override
                    public int getBatchSize() {
                        return 2;
        List<Foo> list = new ArrayList<>();
        list.add(Foo.builder().id(100L).bar("b-100").build());
        list.add(Foo.builder().id(101L).bar("b-101").build());
                .batchUpdate("INSERT INTO FOO (ID, BAR) VALUES (:id, :bar)",
                        SqlParameterSourceUtils.createBatch(list));
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
1.4、启动类
package com.zhz.springbootjdbcdemo;
import com.zhz.springbootjdbcdemo.dao.BatchFooDao;
import com.zhz.springbootjdbcdemo.dao.FooDao;
import org.springframework.boot.CommandLineRunner;
import org.springframework.boot.SpringApplication;
import org.springframework.boot.autoconfigure.SpringBootApplication;
import org.springframework.context.annotation.Bean;
import javax.sql.DataSource;
 * @author mac
@SpringBootApplication
@Slf4j
public class SpringBootJdbcDemoApplication implements CommandLineRunner {
    @Autowired
    private FooDao fooDao;
    @Autowired
    private BatchFooDao batchFooDao;
        SpringApplication.run(SpringBootJdbcDemoApplication.class, args);
    @Bean
    @Autowired
    public SimpleJdbcInsert simpleJdbcInsert(JdbcTemplate jdbcTemplate){
        return new SimpleJdbcInsert(jdbcTemplate).withTableName("foo").usingGeneratedKeyColumns("id");
    @Bean
    @Autowired
    public NamedParameterJdbcTemplate namedParameterJdbcTemplate(DataSource dataSource){
        return new NamedParameterJdbcTemplate(dataSource);
    @Override
    public void run(String... args) throws Exception {
        fooDao.insertData();
        batchFooDao.batchInsert();
        fooDao.listData();
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
1.5、sql
CREATE TABLE FOO (ID INT IDENTITY, BAR VARCHAR(64));
INSERT INTO FOO (BAR) VALUES ('aaa');
文章来源: blog.csdn.net,作者:zhz小白,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/zhouhengzhe/article/details/122431588
