【Android 应用开发】Android之Bluetooth编程
韩曙亮 发表于 2022/01/11 02:05:13 2022/01/11
【摘要】 Android Bluetopth 编程大牛文章 http://my.oschina.net/u/994235/blog?catalog=313604 ViewGroup 相关资料 :  http://www.incoding.org/admin/archives/199.html http://bbs...
ViewGroup 相关资料 :
http://bbs.csdn.net/topics/370144745
http://www.linuxidc.com/Linux/2013-01/78109.htm
http://blog.csdn.net/arui319/article/details/5868466
http://www.2cto.com/kf/201109/104633.html
http://www.cnblogs.com/slider/archive/2011/11/24/2262161.html
蓝牙开发指南 :
http://wenku.baidu.com/view/b41c1b09bb68a98271fefae1.html
蓝牙编程 :
http://wenku.baidu.com/link?url=QT1NMnkqNk3Emm_CueUyqtawXyQ2-CNIu5Es6xgtbj2KLUe5Cu5mXo2xDbvnBRLuvH044uiF2Vhcwjz4o8uCdkYYiUV3R71Id4GIdEQsPLe
http://blog.csdn.net/qinjuning/article/details/7726093  BluetoothAdapter类简介
http://www.cnblogs.com/over140/archive/2010/12/21/1912460.html
Android 中文API (69) —— BluetoothAdapter[蓝牙]
http://www.wuphone.com/579.html BluetoothAdapter蓝牙
http://www.cnblogs.com/over140/archive/2010/12/21/1912482.html
BluetoothDevice[蓝牙]
http://blog.csdn.net/hellogv/article/details/6042091 十三篇之探秘蓝牙隐藏API
http://www.cnblogs.com/wanqieddy/archive/2013/05/24/3096312.html 隐藏api介绍
http://www.eoeandroid.com/thread-18993-1-1.html?_dsign=d70c243d Android蓝牙开发浅谈
http://blog.csdn.net/myarrow/article/details/8143717 安卓设备待机广播
http://www.cnblogs.com/fbsk/archive/2011/10/10/2205316.html
Android开机自启动程序
http://wenku.baidu.com/view/6baf53eaaeaad1f346933f85.html
http://android.toolib.net/reference/android/bluetooth/BluetoothServerSocket.html
BlueToothServerSocket API解析
http://jinguo.iteye.com/blog/687357
http://android.toolib.net/reference/android/bluetooth/BluetoothSocket.html
BlueToothSocket API解析
http://blog.csdn.net/xiluoduyu/article/details/8515286
http://www.linuxidc.com/Linux/2012-09/69586.htm
蓝牙模块开发
使用代码打开蓝牙
Intent enableBtIntent = new Intent(BluetoothAdapter.ACTION_REQUEST_ENABLE);
System.out.println(" 打开蓝牙 ");
startActivityForResult(enableBtIntent, REQUEST_ENABLE_BT);
http://my.oschina.net/billowworld/blog/62975
如何实现android蓝牙开发 自动配对连接,并不弹出提示框
Android中通过静态注册的屏幕开启和屏幕关闭的BroadCastReceiver为什么捕捉不到广播?
android开发中使用AndroidManiFest.xml静态注册的BroadCastReceiver没有作用是什么原因?
请输入图片描述
请输入图片描述
使用静态注册,Debug运行,就是没进到onReceive()方法那里去。我用真机调试的。
但是使用动态注册,又可以捕捉到。我想问,这个系统广播可不可以静态注册?如果可以为什么会捕捉不到呢?
在Android 的广播机制中,动态注册的优先级是要高于静态注册优先级的,你是否在调试时2个都注册了,所以出现你的这种情况;当用来注册动态广播接收器的activity被关闭时,这个动态接收器也就是就失效了,静态注册的广播接收器只要有你注册的广播出现就能接收到广播。
对于这两个action:
android.intent.action.SCREEN_OFF
android.intent.action.SCREEN_ON
在AndroidManifest.xml中注册是不可以的。
这有点不同于其他的action,你只有在Service中通过动态注册去监听这个事件。
这个问题我的理解是google故意这么做的,有两点考虑:
1.提高监听screen_on screen_off门槛
这两个事件是android的基本事件,如果呗大多数程序监听,会大大的拖慢整个系统,所以android也应该不鼓励我们在后台监听这两个事件。
2.有让我们在service后台监听
这也是提供了一个解决问题,强调和service共存亡,不会一直在后台无限情运行。
总之应该是为了保证系统的稳定和安全才采取这样的措施。
希望对你有帮助。
蓝牙配对密码设置
先是写个
<receiver android:name=".broadcast.PairingRequest">
                  <intent-filter>
                    <action android:name="android.bluetooth.device.action.PAIRING_REQUEST" />
                    <action android:name="android.bluetooth.device.action.PAIRING_CANCEL" />
                  </intent-filter>
                </receiver>
然后是你的
public class PairingRequest extends BroadcastReceiver{
  @Override
  public void onReceive(Context context, Intent intent){
    if (intent.getAction().equals("ACTION_PAIRING_REQUEST")) {
            BluetoothDevice device = intent.getParcelableExtra(BluetoothDevice.EXTRA_DEVICE);
            byte[] pinBytes = BluetoothDevice.convertPinToBytes("1234");
            device.setPin(pinBytes);
其中的蓝牙BluetoothDevice这个类要用源码里的替换下
蓝牙设备是怎么连接的
最前提的条件是有蓝牙的MAC地址; String macAddress;
根据蓝牙的MAC地址 , 可以获得蓝牙设备BluetoothDevice对象 , BluetoothDevice device = bluetoothAdapter.getRemoteDevice(macAddress);
将蓝牙设备对象传入服务中的connect方法中;
将设备连接放在线程中完成 , 创建一个设备连接的线程 , 启动这个线程.
BluetoothAdapter资料 :
关于权限资料
 android.permission.BLUETOOTH 允许程序连接到已配对的蓝牙设备(Allows applications to connect to paired bluetooth devices)
  android.permission.BLUETOOTH_ADMIN 允许程序发现和配对蓝牙设备(Allows applications to discover and pair bluetooth devices)
android蓝牙开发——权限
为了在应用程序中使用蓝牙功能,我们至少需要声明两方面的权限:BLUETOOTH和BLUETOOTH_ADMIN。
你必须请求BLUETOOTH权限才能够实现蓝牙通信,例如请求一个连接、接受一个连接和传输数据。
你必须请求BLUETOOTH_ADMIN权限,才能够初始化device discovery或者管理蓝牙设置(Bluetooth settings)。大多数应用程序必须具有这个权限才能够发现本地蓝牙设备,这个权限保护的其他能力(除了发现本地设备)不应该被使用,除非你的应用程序是在用户请求的时候能够修改蓝牙设置的管理者。
注意:如果你想要使用BLUETOOTH_ADMIN权限,那么你首先必须有BLUETOOTH权限。
你需要在应用程序的manifest文件中声明程序的蓝牙权限。例如:
[xhtml]  view plain copy
  1. <manifest ... >
  2.   <uses-permission android:name="android.permission.BLUETOOTH" />
  3.   ...
  4. </manifest>
关于声明应用程序权限的信息,请看<uses-permission>参考。
原文链接:hanshuliang.blog.csdn.net/article/details/11989681
