【Android 异步操作】Handler 机制 ( MessageQueue 空闲任务 IdleHandler 机制 )
韩曙亮 发表于 2022/01/10 23:39:03 2022/01/10
【摘要】 文章目录 一、MessageQueue 空闲任务 IdleHandler 机制二、MessageQueue 中空闲任务 IdleHandler 相关源码 一、MessageQ...
在 消息队列 MessageQueue 的 next 获取下一条消息的方法中 ,
在循环获取消息的最后有如下代码 :
public final class MessageQueue {
    @UnsupportedAppUsage
    Message next() {
                // If first time idle, then get the number of idlers to run.
                // Idle handles only run if the queue is empty or if the first message
                // in the queue (possibly a barrier) is due to be handled in the future.
                if (pendingIdleHandlerCount < 0
                        && (mMessages == null || now < mMessages.when)) {
                    // 如果取出的 消息为空 , 就会执行 IdleHandler
                    pendingIdleHandlerCount = mIdleHandlers.size();
                if (pendingIdleHandlerCount <= 0) {
                    // No idle handlers to run.  Loop and wait some more.
                    mBlocked = true;
                    continue;
                if (mPendingIdleHandlers == null) {
                    mPendingIdleHandlers = new IdleHandler[Math.max(pendingIdleHandlerCount, 4)];
                mPendingIdleHandlers = mIdleHandlers.toArray(mPendingIdleHandlers);
开始判定 pendingIdleHandlerCount 大小 , 如果小于 0 0 0 则执行后续 与 IdleHandler 相关操作 ;
IdleHandler 是一个 接口 , 代码如下 :
     * Callback interface for discovering when a thread is going to block
     * waiting for more messages.
    public static interface IdleHandler {
         * Called when the message queue has run out of messages and will now
         * wait for more.  Return true to keep your idle handler active, false
         * to have it removed.  This may be called if there are still messages
         * pending in the queue, but they are all scheduled to be dispatched
         * after the current time.
        boolean queueIdle();
在上述如果取出的 mMessage 消息为空 mMessages == null , 则执行 IdleHandler ;
IdleHandler 使用时 , 调用 addIdleHandler 函数 , 该函数会将 IdleHandler 加入到 mIdleHandlers 集合中 ,
MessageQueue 消息队列 addIdleHandler 函数如下 :
     * Add a new {@link IdleHandler} to this message queue.  This may be
     * removed automatically for you by returning false from
     * {@link IdleHandler#queueIdle IdleHandler.queueIdle()} when it is
     * invoked, or explicitly removing it with {@link #removeIdleHandler}.
     * <p>This method is safe to call from any thread.
     * @param handler The IdleHandler to be added.
    public void addIdleHandler(@NonNull IdleHandler handler) {
        if (handler == null) {
            throw new NullPointerException("Can't add a null IdleHandler");
        synchronized (this) {
            mIdleHandlers.add(handler);
在 MessageQueue 的 next 方法中继续向下执行 , 开始遍历 mIdleHandlers 集合 , 先将集合 mIdleHandlers 转为 mPendingIdleHandlers 数组 , 然后遍历该数组 ,
遍历时 , 调用 IdleHandler 对象的 queueIdle 方法 ,
如果上面的 queueIdle 方法返回值是 false , 就会从 mIdleHandlers 集合中 移除该元素 ,
如果上面的 queueIdle 方法返回值是 true , 那么下一次再次执行到这里时 , 还会 继续回调该函数 ;
上述操作对应的 MessageQueue 的 next 方法内的部分源码 :
    Message next() {
            // Run the idle handlers.
            // We only ever reach this code block during the first iteration.
            for (int i = 0; i < pendingIdleHandlerCount; i++) {
                final IdleHandler idler = mPendingIdleHandlers[i];
                mPendingIdleHandlers[i] = null; // release the reference to the handler
                boolean keep = false;
                try {
                    keep = idler.queueIdle();
                } catch (Throwable t) {
                    Log.wtf(TAG, "IdleHandler threw exception", t);
                if (!keep) {
                        mIdleHandlers.remove(idler);
            // Reset the idle handler count to 0 so we do not run them again.
            pendingIdleHandlerCount = 0;
            // While calling an idle handler, a new message could have been delivered
            // so go back and look again for a pending message without waiting.
            nextPollTimeoutMillis = 0;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
IdleHandler 的作用是 , 当消息队列 MessageQueue 中没有消息处理时 , 处于闲置状态时 , 此时就会回调一次用户注册的 IdleHandler ,
如果该 IdleHandler 的 queueIdle 方法返回 false , 那么该 IdleHandler 只会 执行一次 ,
如果该 IdleHandler 的 queueIdle 方法返回 true , 则 每次空闲 , 都要执行一次该 IdleHandler ;
    Message mMessages;
    private final ArrayList<IdleHandler> mIdleHandlers = new ArrayList<IdleHandler>();
    private IdleHandler[] mPendingIdleHandlers;
    Message next() {
        // Return here if the message loop has already quit and been disposed.
        // This can happen if the application tries to restart a looper after quit
        // which is not supported.
        final long ptr = mPtr;
        if (ptr == 0) {
            return null;
        int pendingIdleHandlerCount = -1; // -1 only during first iteration
        int nextPollTimeoutMillis = 0;
        for (;;) {
            if (nextPollTimeoutMillis != 0) {
                Binder.flushPendingCommands();
            nativePollOnce(ptr, nextPollTimeoutMillis);
             	// 获取当前的时间 , 需要判定是否有需要延迟发送的消息
                // Try to retrieve the next message.  Return if found.
                final long now = SystemClock.uptimeMillis();
                Message prevMsg = null;
                Message msg = mMessages;
                if (msg != null && msg.target == null) {
                    // Stalled by a barrier.  Find the next asynchronous message in the queue.
                    do {
                        prevMsg = msg;
                        msg = msg.next;
                    } while (msg != null && !msg.isAsynchronous());
                if (msg != null) {
                    if (now < msg.when) {
                        // Next message is not ready.  Set a timeout to wake up when it is ready.
                        nextPollTimeoutMillis = (int) Math.min(msg.when - now, Integer.MAX_VALUE);
                        // Got a message.
                        mBlocked = false;
                        if (prevMsg != null) {
                            prevMsg.next = msg.next;
                            mMessages = msg.next;
                        msg.next = null;
                        if (DEBUG) Log.v(TAG, "Returning message: " + msg);
                        msg.markInUse();
                        return msg;
                    // No more messages.
                    nextPollTimeoutMillis = -1;
                // Process the quit message now that all pending messages have been handled.
                if (mQuitting) {
                    dispose();
                    return null;
                    mBlocked = true;
                    continue;
                try {
                if (!keep) {
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
原文链接:hanshuliang.blog.csdn.net/article/details/109512749
