Opencv基础使用1——分割 - 视频人像跟踪
墨理学AI 发表于 2022/01/10 22:57:33 2022/01/10
【摘要】 opencv-master 4.5.1 - Python 示例代码运行测试 ( 一 ) | 分割 - 视频人像跟踪 文章目录 环境搭建opencv-master4.5.1 Python...
环境搭建
系统环境 【 这里是用的 Linux 虚拟机 】
cat /etc/issue
Ubuntu 20.04.2 LTS \n \l
conda 新建独立环境如下:
conda create -n py369 python=3.6.9
conda activate py369
pip install opencv-python
pip install matplotlib
pip install numpy
运行环境 pip list 如下:
pip list
Package         Version
certifi         2020.12.5
cycler          0.10.0
kiwisolver      1.3.1
matplotlib      3.3.4
numpy           1.19.5
opencv-python   4.5.1.48
Pillow          8.2.0
pip             21.0.1
pyparsing       2.4.7
python-dateutil 2.8.1
setuptools      52.0.0.post20210125
six             1.15.0
wheel           0.36.2
opencv-master4.5.1源码下载地址
其它版本下载地址:https://github.com/opencv/opencv/releases
  • 本博文的测试是直接拉取 opencv-master4.5.1,然后在opencv/samples/python/tutorial_code/ImgTrans 目录下对相应 py 文件进行测试
0-9
opencv-master4.5.1 Python 边缘检测算子测试
测试所输入数据
  • opencv-master4.5.1/opencv/samples/data 目录下有测试可用数据
lena.jpg 原图:
cd pyOpenCVLearn/opencv/samples/python
cp opencv/samples/data/lena.jpg .
0-0
Sobel 算子
cd pyOpenCVLearn/opencv/samples/python/tutorial_code/ImgTrans/SobelDemo
python sobel_demo.py ../../../lena.jpg
运行效果如下:
1-0
LaPlace 算子
cd pyOpenCVLearn/opencv/samples/python/tutorial_code/ImgTrans/LaPlace
python laplace_demo.py ../../../lena.jpg
1-1
canny 算子 detector
cd pyOpenCVLearn/opencv/samples/python/tutorial_code/ImgTrans/canny_detector
python CannyDetector_Demo.py --input ../../../lena.jpg
运行效果如下:
1-2
图像分割测试
Code for Image Segmentation with Distance Transform and Watershed Algorithm
cd opencv/samples/python/tutorial_code/ImgTrans/distance_transformation
python imageSegmentation.py --input ../../../../data/cards.png
效果如下:
2-2
计算 视频帧的 PSNR 、SSIM
这个代码感觉对于 超分重建 PSNR 计算还是有些许参考价值的;
cd opencv/samples/python/tutorial_code/videoio
python video-input-psnr-ssim.py -r ../../../data/Megamind.avi -t ../../../data/Megamind_bugy.avi
输出大致如下:
Frame: 0# 0dB
Frame: 1# 41.279dB
Frame: 2# 41.354dB
Frame: 3# 41.201dB
Frame: 4# 41.043dB
Frame: 5# 19.214dB MSSISM: R 94.69% G 93.39% B 90.06%
Frame: 6# 40.818dB
Frame: 7# 41.046dB
Frame: 8# 40.919dB
Frame: 9# 41.166dB
Frame: 10# 15.832dB MSSISM: R 93.17% G 91.99% B 88.64%
Frame: 11# 40.767dB
Frame: 12# 41.016dB
Frame: 13# 40.746dB
Frame: 14# 41.186dB
Frame: 15# 40.297dB
Frame: 16# 40.44dB
Frame: 17# 40.97dB
Frame: 18# 40.846dB
Frame: 19# 40.727dB
Frame: 20# 22.09dB MSSISM: R 94.64% G 93.88% B 90.64%
Frame: 21# 40.953dB
Frame: 22# 40.845dB
Frame: 23# 40.894dB
Frame: 24# 40.776dB
Frame: 25# 22.021dB MSSISM: R 93.1% G 91.86% B 89.21%
Frame: 26# 40.067dB
Frame: 27# 39.661dB
Frame: 28# 39.176dB
Frame: 29# 39.289dB
Frame: 30# 21.877dB MSSISM: R 90.4% G 88.64% B 86.24%
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
Background subtraction method(视频人像跟踪 - 背景提取)
cd opencv/samples/python/tutorial_code/video/background_subtraction
python bg_sub.py --input ../../../../data/vtest.avi
效果如下:
5-1
# Background subtraction method (KNN, MOG2)
# 算法设置为 KNN 测试如下:
python bg_sub.py --input ../../../../data/vtest.avi --algo KNN
5-2
基于颜色分布的连续自适应均值漂移【跟踪】算法(camshift algorithm)
有兴趣了解这个算法可以自行检索该算法相关文献:
例如:基于Camshift算法的小球跟踪
脚本运行输入
输入是一个 mp4 需要自行点击下载
运行代码如下:
# 下载的 mp4  文件 copy 到 opencv/samples/data/ 目录下
cp slow_traffic_small.mp4  opencv/samples/data/
cd opencv/samples/python/tutorial_code/video/meanshift
# 运行输入如下:
python camshift.py ../../../../data/slow_traffic_small.mp4
# 另外一个 meanshift.py 脚本也可以运行测试:
python meanshift.py ../../../../data/slow_traffic_small.mp4
运行效果如下:
5-3
Lucas-Kanade Optical Flow calculation【光流计算跟踪】
运行代码如下:
cd opencv/samples/python/tutorial_code/video/optical_flow
python optical_flow.py ../../../../data/slow_traffic_small.mp4
运行效果如下:
5-5
运行代码如下:
# 需要 把 vtest.avi copy 到当前目录作为默认输入
cp ../../../../data/vtest.avi .
python optical_flow_dense.py
效果如下:
5-6
This program demonstrates line finding with the Hough transform【使用霍夫变换进行寻线的过程】
运行代码如下:
cd  /opencv/samples/python/tutorial_code/ImgTrans/HoughLine
# 把 opencv-master4.5.1\opencv\samples\data 目录下 代码使用的 数据 copy 到 当前目录
cp ../../../../data/sudoku.png .
python hough_lines.py
# 或者另一个 方法
cd ../HoughCircle/
cp ../../../../data/smarties.png .
运行效果如下:
6-1
6-2
Sample code that shows the functionality of copyMakeBorder【检测 图像边框】
运行代码如下:
cd opencv/samples/python/tutorial_code/ImgTrans/MakeBorder
cp ../../../../data/lena.jpg .
python copy_make_border.py
效果如下:
7-1
镜像 翻转
运行代码如下:
cd opencv/samples/python/tutorial_code/ImgTrans/remap
python Remap_Demo.py --input ../../../../data/chicky_512.png
效果如下:
7-2
图像变形 – 旋转角度
运行代码如下:
cd opencv/samples/python/tutorial_code/ImgTrans/warp_affine
python Geometric_Transforms_Demo.py --input ../../../../data/lena.jpg
效果如下:
7-3
文章来源: positive.blog.csdn.net,作者:墨理学AI,版权归原作者所有,如需转载,请联系作者。
原文链接:positive.blog.csdn.net/article/details/117224999
