斐波那契数列 | Fibonacci sequence | Python实现
墨理学AI 发表于 2022/01/10 23:20:34 2022/01/10
【摘要】 斐波那契数列: [ 0, 1, 1, 2, 3, 5, 8, 13, 21, 34, 55, 89, 144, 233, 377, 610, 987, 1597, 2584, 4181, ...
斐波那契数列:
[ 0, 1, 1, 2, 3, 5, 8, 13, 21, 34, 55, 89, 144, 233, 377, 610, 987, 1597, 2584, 4181, 6765 … ]
这个数列从第3项开始,每一项都等于前两项之和
Python实现
import sys
#循环 返回第 n 个 数
def loop(n):
	first,second = 0,1
	for i in range(n):
		first,second = second,first+second
	return first
#循环,返回斐波那契数列
def fib(n):
	v = [0, 1]
	for i in range(2,n+1):
		v.append(v[i-1] + v[i-2])
	return v
	# return v[n]
if __name__ == '__main__':
    print(fib(int(sys.argv[1])))
    print("loop = %d " % loop(int(sys.argv[1])))
C语言实现
递归 相对于循环而言,有非常大的函数时间消耗
#include <stdio.h>
#include <time.h>
//递归计算斐波那契数
long fib_recursion(int n) {
    if (n <= 2) {
        return 1;
    else {
        return fib_recursion(n - 1) + fib_recursion(n - 2);
//迭代计算斐波那契数
long fib_iteration(int n){
    long result;
    long previous_result;
    long next_older_result;
    result = previous_result = 1;
    while (n > 2) {
        n -= 1;
        next_older_result = previous_result;
        previous_result = result;
        result = previous_result + next_older_result;
    return result;
int main() {
    int a;
    clock_t time_start_recursion, time_end_recursion;
    clock_t time_start_iteration, time_end_iteration;
    printf("Input a number: ");
    scanf("%d", &a);
    //递归的时间
    time_start_recursion = clock();
    printf("Fib_recursion(%d) = %ld\n", a, fib_recursion(a));
    time_end_recursion = clock();
    printf("run time with recursion: %lfs\n", (double)(time_end_recursion - time_start_recursion)/ CLOCKS_PER_SEC );
    //迭代的时间
    time_start_iteration = clock();
    printf("Fib_iteration(%d) = %ld\n", a, fib_iteration(a));
    time_end_iteration = clock();
    printf("run time with iteration: %lfs\n", (double)(time_end_iteration - time_start_iteration) / CLOCKS_PER_SEC);
    return 0;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
时间消耗对比如下:
gcc loop.c
./a.out
Input a number: 45
Fib_recursion(45) = 1134903170
run time with recursion: 5.449947s
Fib_iteration(45) = 1134903170
run time with iteration: 0.000003s
文章来源: positive.blog.csdn.net,作者:墨理学AI,版权归原作者所有,如需转载,请联系作者。
原文链接:positive.blog.csdn.net/article/details/117222932
