微信小程序使用md5加密(支持中文)
程思扬 发表于 2022/01/06 22:00:14 2022/01/06
【摘要】 由于本人最近在学小程序,刚好用到md5,之前用别人的中文会有bug,现在就给大家分享一下微信小程序引入md5.js的方法,不多说 md5.js在下面 ,新建md5.js文件,直接复制到项目的utils/md5.js即可
```java
 * A JavaScript implementation of the RSA Data Security, Inc. MD5 Message
 * Digest Algorithm, as defined in RFC 1321.
 * Version 1.1 Copyright (C) Paul Johnston 1999 - 2002.
 * Code also contributed by Greg Holt
 * See http://pajhome.org.uk/site/legal.html for details.
 * Add integers, wrapping at 2^32. This uses 16-bit operations internally
 * to work around bugs in some JS interpreters.
function safe_add(x, y)
 var lsw = (x & 0xFFFF) + (y & 0xFFFF)
 var msw = (x >> 16) + (y >> 16) + (lsw >> 16)
 return (msw << 16) | (lsw & 0xFFFF)
 * Bitwise rotate a 32-bit number to the left.
function rol(num, cnt)
 return (num << cnt) | (num >>> (32 - cnt))
 * These functions implement the four basic operations the algorithm uses.
function cmn(q, a, b, x, s, t)
 return safe_add(rol(safe_add(safe_add(a, q), safe_add(x, t)), s), b)
function ff(a, b, c, d, x, s, t)
 return cmn((b & c) | ((~b) & d), a, b, x, s, t)
function gg(a, b, c, d, x, s, t)
 return cmn((b & d) | (c & (~d)), a, b, x, s, t)
function hh(a, b, c, d, x, s, t)
 return cmn(b ^ c ^ d, a, b, x, s, t)
function ii(a, b, c, d, x, s, t)
 return cmn(c ^ (b | (~d)), a, b, x, s, t)
 * Calculate the MD5 of an array of little-endian words, producing an array
 * of little-endian words.
function coreMD5(x)
 var a = 1732584193
 var b = -271733879
 var c = -1732584194
 var d = 271733878
 for(var i = 0; i < x.length; i += 16)
  var olda = a
  var oldb = b
  var oldc = c
  var oldd = d
  a = ff(a, b, c, d, x[i+ 0], 7 , -680876936)
  d = ff(d, a, b, c, x[i+ 1], 12, -389564586)
  c = ff(c, d, a, b, x[i+ 2], 17, 606105819)
  b = ff(b, c, d, a, x[i+ 3], 22, -1044525330)
  a = ff(a, b, c, d, x[i+ 4], 7 , -176418897)
  d = ff(d, a, b, c, x[i+ 5], 12, 1200080426)
  c = ff(c, d, a, b, x[i+ 6], 17, -1473231341)
  b = ff(b, c, d, a, x[i+ 7], 22, -45705983)
  a = ff(a, b, c, d, x[i+ 8], 7 , 1770035416)
  d = ff(d, a, b, c, x[i+ 9], 12, -1958414417)
  c = ff(c, d, a, b, x[i+10], 17, -42063)
  b = ff(b, c, d, a, x[i+11], 22, -1990404162)
  a = ff(a, b, c, d, x[i+12], 7 , 1804603682)
  d = ff(d, a, b, c, x[i+13], 12, -40341101)
  c = ff(c, d, a, b, x[i+14], 17, -1502002290)
  b = ff(b, c, d, a, x[i+15], 22, 1236535329)
  a = gg(a, b, c, d, x[i+ 1], 5 , -165796510)
  d = gg(d, a, b, c, x[i+ 6], 9 , -1069501632)
  c = gg(c, d, a, b, x[i+11], 14, 643717713)
  b = gg(b, c, d, a, x[i+ 0], 20, -373897302)
  a = gg(a, b, c, d, x[i+ 5], 5 , -701558691)
  d = gg(d, a, b, c, x[i+10], 9 , 38016083)
  c = gg(c, d, a, b, x[i+15], 14, -660478335)
  b = gg(b, c, d, a, x[i+ 4], 20, -405537848)
  a = gg(a, b, c, d, x[i+ 9], 5 , 568446438)
  d = gg(d, a, b, c, x[i+14], 9 , -1019803690)
  c = gg(c, d, a, b, x[i+ 3], 14, -187363961)
  b = gg(b, c, d, a, x[i+ 8], 20, 1163531501)
  a = gg(a, b, c, d, x[i+13], 5 , -1444681467)
  d = gg(d, a, b, c, x[i+ 2], 9 , -51403784)
  c = gg(c, d, a, b, x[i+ 7], 14, 1735328473)
  b = gg(b, c, d, a, x[i+12], 20, -1926607734)
  a = hh(a, b, c, d, x[i+ 5], 4 , -378558)
  d = hh(d, a, b, c, x[i+ 8], 11, -2022574463)
  c = hh(c, d, a, b, x[i+11], 16, 1839030562)
  b = hh(b, c, d, a, x[i+14], 23, -35309556)
  a = hh(a, b, c, d, x[i+ 1], 4 , -1530992060)
  d = hh(d, a, b, c, x[i+ 4], 11, 1272893353)
  c = hh(c, d, a, b, x[i+ 7], 16, -155497632)
  b = hh(b, c, d, a, x[i+10], 23, -1094730640)
  a = hh(a, b, c, d, x[i+13], 4 , 681279174)
  d = hh(d, a, b, c, x[i+ 0], 11, -358537222)
  c = hh(c, d, a, b, x[i+ 3], 16, -722521979)
  b = hh(b, c, d, a, x[i+ 6], 23, 76029189)
  a = hh(a, b, c, d, x[i+ 9], 4 , -640364487)
  d = hh(d, a, b, c, x[i+12], 11, -421815835)
  c = hh(c, d, a, b, x[i+15], 16, 530742520)
  b = hh(b, c, d, a, x[i+ 2], 23, -995338651)
  a = ii(a, b, c, d, x[i+ 0], 6 , -198630844)
  d = ii(d, a, b, c, x[i+ 7], 10, 1126891415)
  c = ii(c, d, a, b, x[i+14], 15, -1416354905)
  b = ii(b, c, d, a, x[i+ 5], 21, -57434055)
  a = ii(a, b, c, d, x[i+12], 6 , 1700485571)
  d = ii(d, a, b, c, x[i+ 3], 10, -1894986606)
  c = ii(c, d, a, b, x[i+10], 15, -1051523)
  b = ii(b, c, d, a, x[i+ 1], 21, -2054922799)
  a = ii(a, b, c, d, x[i+ 8], 6 , 1873313359)
  d = ii(d, a, b, c, x[i+15], 10, -30611744)
  c = ii(c, d, a, b, x[i+ 6], 15, -1560198380)
  b = ii(b, c, d, a, x[i+13], 21, 1309151649)
  a = ii(a, b, c, d, x[i+ 4], 6 , -145523070)
  d = ii(d, a, b, c, x[i+11], 10, -1120210379)
  c = ii(c, d, a, b, x[i+ 2], 15, 718787259)
  b = ii(b, c, d, a, x[i+ 9], 21, -343485551)
  a = safe_add(a, olda)
  b = safe_add(b, oldb)
  c = safe_add(c, oldc)
  d = safe_add(d, oldd)
 return [a, b, c, d]
 * Convert an array of little-endian words to a hex string.
function binl2hex(binarray)
 var hex_tab = "0123456789abcdef"
 var str = ""
 for(var i = 0; i < binarray.length * 4; i++)
  str += hex_tab.charAt((binarray[i>>2] >> ((i%4)*8+4)) & 0xF) +
      hex_tab.charAt((binarray[i>>2] >> ((i%4)*8)) & 0xF)
 return str
 * Convert an array of little-endian words to a base64 encoded string.
function binl2b64(binarray)
 var tab = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/"
 var str = ""
 for(var i = 0; i < binarray.length * 32; i += 6)
  str += tab.charAt(((binarray[i>>5] << (i%32)) & 0x3F) |
           ((binarray[i>>5+1] >> (32-i%32)) & 0x3F))
 return str
 * Convert an 8-bit character string to a sequence of 16-word blocks, stored
 * as an array, and append appropriate padding for MD4/5 calculation.
 * If any of the characters are >255, the high byte is silently ignored.
function str2binl(str)
 var nblk = ((str.length + 8) >> 6) + 1 // number of 16-word blocks
 var blks = new Array(nblk * 16)
 for(var i = 0; i < nblk * 16; i++) blks[i] = 0
 for(var i = 0; i < str.length; i++)
  blks[i>>2] |= (str.charCodeAt(i) & 0xFF) << ((i%4) * 8)
 blks[i>>2] |= 0x80 << ((i%4) * 8)
 blks[nblk*16-2] = str.length * 8
 return blks
 * Convert a wide-character string to a sequence of 16-word blocks, stored as
 * an array, and append appropriate padding for MD4/5 calculation.
function strw2binl(str)
 var nblk = ((str.length + 4) >> 5) + 1 // number of 16-word blocks
  blks[i>>1] |= str.charCodeAt(i) << ((i%2) * 16)
 blks[i>>1] |= 0x80 << ((i%2) * 16)
 blks[nblk*16-2] = str.length * 16
 return blks
 * External interface
function hexMD5 (str) { return binl2hex(coreMD5( str2binl(str))) }
function hexMD5w(str) { return binl2hex(coreMD5(strw2binl(str))) }
function b64MD5 (str) { return binl2b64(coreMD5( str2binl(str))) }
function b64MD5w(str) { return binl2b64(coreMD5(strw2binl(str))) }
/* Backward compatibility */
function calcMD5(str) { return binl2hex(coreMD5( str2binl(str))) }
module.exports = {
 hexMD5: hexMD5
使用方法 : 在该有的页面进行如下引入即可
```java
var utilMd5 = require('../../utils/md5.js');
var password = utilMd5.hexMD5(password);
或者这么使用
```java
import { hexMD5 } from "./utils/md5.js"
    console.log(hexMD5("123"));
