读取NFC 卡片的ID
程思扬 发表于 2022/01/05 15:36:09 2022/01/05
【摘要】 读取NFC 卡片的ID
初始化适配器 NfcAdapter PendingIntent
Intent nfcIntent = new Intent(this, getClass());
nfcIntent.addFlags(Intent.FLAG_ACTIVITY_SINGLE_TOP);
mAdapter = NfcAdapter.getDefaultAdapter(this);
mPendingIntent = PendingIntent.getActivity(this, 0, nfcIntent, 0);
 String infoText = "看下这个支持nfc吗 或者 开了没";
 if (mAdapter == null) {
      Toast.makeText(getApplicationContext(),
      infoText, Toast.LENGTH_SHORT).show();
重写onNewIntent()方法
 @Override
 protected void onNewIntent(Intent intent) {
 Tag tag=intent.getParcelableExtra(NfcAdapter.EXTRA_TAG);
 //获取 Tag 读取 ID 得到字节数组 转字符串 转码 得到卡号(默认16进制 这请自便)
 Long cardNo = Long.parseLong(flipHexStr(ByteArrayToHexString(tag.getId())), 16);
 // if (cardNo.toString().getBytes().length == 10) {
 num = cardNo.toString();
  // } else {
   // 转的时候有个地方需要注意下 如果开头为零的话 会省略所以位数会改变
   // num = "0" + cardNo.toString();
   TextView textView = (TextView) findViewById(R.id.nfc_text);
   textView.setText(num);
   Toast.makeText(getApplicationContext(), num, Toast.LENGTH_SHORT).show();
息屏之类的操作
@Override
public void onPause() {
 super.onPause();
  if (mAdapter != null) {
  mAdapter.disableForegroundDispatch(this);
@Override
 public void onResume() {
 super.onResume();
 mAdapter.enableForegroundDispatch(this, mPendingIntent, null, null);
最后附上转码工具类
public class ByteArrayTohexHepler {
    public static String flipHexStr(String s) {
      StringBuilder result = new StringBuilder();
      for (int i = 0; i <= s.length() - 2; i = i + 2) {
     result.append(new StringBuilder(s.substring(i, i + 2)).reverse());
   return result.reverse().toString();
  // 16转10进制
  public static String ByteArrayToHexString(byte[] inarray) {
  int i, j, in;
  String[] hex = {"0", "1", "2", "3", "4", "5", "6", "7", "8", "9", "A", "B", "C", "D", "E", "F"};
  StringBuilder out = new StringBuilder();
   for (j = 0; j < inarray.length; ++j) {
    in = (int) inarray[j] & 0xff;
    i = (in >> 4) & 0x0f;
   out.append(hex[i]);
   i = in & 0x0f;
   out.append(hex[i]);
   } return out.toString();
大家有什么问题可以在下方留言
