十天学会微信小程序开发指南(六)
府学路18号车神 发表于 2022/01/04 09:21:53 2022/01/04
【摘要】 十天学会微信小程序开发,一起来学习吧!~
day07 功能
1.发布
1.1 小程序
  • 选图片
  • 填内容
  • 提交
        cover:"https://mini-1251317460.cos.ap-chengdu.myqcloud.com/08a9daei1578736867828.png",
        content:"小程序开发太简单了",
        address:"北京市",
        topic:1,
        images:[
        address:"北京市",
        topic:1,
        images:[
                path:"https://mini-1251317460.cos.ap-chengdu.myqcloud.com/08a9daei1578736867828.png",
                cos_key:"08a9daei1578736867828.pn"
1.2 API
from rest_framework.views import APIView
from rest_framework.generics import CreateAPIView
from rest_framework import serializers
from apps.api import models
class NewsDetailModelSerializer(serializers.Serializer):
    key = serializers.CharField()
    cos_path = serializers.CharField()
class NewsModelSerializer(serializers.ModelSerializer):
    images = NewsDetailModelSerializer(many=True)
    class Meta:
        model = models.News
        fields = "__all__"
class NewsView(CreateAPIView):
    """ 创建动态的API """
    serializer_class = NewsModelSerializer
class News(models.Model):
    动态
    cover = models.CharField(verbose_name='封面', max_length=128)
    content = models.CharField(verbose_name='内容', max_length=255)
    topic = models.ForeignKey(verbose_name='话题', to='Topic', null=True, blank=True)
    address = models.CharField(verbose_name='位置', max_length=128, null=True, blank=True)
    user = models.ForeignKey(verbose_name='发布者', to='UserInfo', related_name='news')
    favor_count = models.PositiveIntegerField(verbose_name='赞数', default=0)
    viewer_count = models.PositiveIntegerField(verbose_name='浏览数', default=0)
    comment_count = models.PositiveIntegerField(verbose_name='评论数', default=0)
    create_date = models.DateTimeField(verbose_name='创建时间', auto_now_add=True)
class NewsDetail(models.Model):
    动态详细
    key = models.CharField(verbose_name='腾讯对象存储中的文件名', max_length=128, help_text="用于以后在腾讯对象存储中删除")
    cos_path = models.CharField(verbose_name='腾讯对象存储中图片路径', max_length=128)
    news = models.ForeignKey(verbose_name='动态', to='News')
1.3 规则
    k1:v1,
    k2:v2,
    k3:{...},
    k4:[
2.restful api回顾
2.1 APIView ( 可以 )
from rest_framework.response import Response
class UserModelSerializer(serializers.ModelSerializer):
    class Meta:
        model = models.UserInfo
        fields = "__all__"
class UserView(APIView):
    def get(self,request,*args,**kwargs):
        user_list = models.UserInfo.objects.all()
        ser = UserModelSerializer(instance=user_list,many=True)
        return Response(ser.data)
    def post(self,request,*args,**kwargs):
        ser = UserModelSerializer(data=request.data)
        if ser.is_valid():
            # models.UserInfo.objects.create(**ser.validated_data)
            ser.save(user_id=1)
        return Response(ser.errors)
2.2 ListAPIView
ListAPIView,CreateAPIView,RetrieveAPIView,UpdateAPIView,DestroyAPIView
class NewTestModelSerializer(serializers.ModelSerializer):
    class Meta:
        model = models.News
        fields = "__all__"
class NewTestView(CreateAPIView,ListAPIView):
    serializer_class = NewTestModelSerializer
    queryset = models.News.objects.filter(id__gt=4)
2.2.1 用户传递某些值
创建用户时,自己在后台生成一个UID。
    class Meta:
        model = models.News
        fields = "__all__"
    def perform_create(self, serializer):
        serializer.save(uid=str(uuid.uuid4()))
2.2.2 fields和exclude的区别?
通过fields和exclude定制页面展示数据。
需求:只显示用户表的id,name,age的数据,其他不显示。
    class Meta:
        model = models.News
        # fields = ["id","name",'age']
        # fields = "__all__"
        exclude = ['gender']
class NewTestView(ListAPIView):
    queryset = models.User.objects.all()
    {id:1,name:'xxx',age:18},
    {id:1,name:'xxx',age:11},
    {id:1,name:'xxx',age:99},
需求:数据库有5个字段,显示7个字段。
    xx = serializers.CharField(source='id')
    x1 = serializers.SerializerMethodField()
    class Meta:
        model = models.News
        # fields = ['id','name','age','gender','phone','xx','x1']
        exclude = ['id','name']
    def get_x1(self,obj):
        return obj.id
    {id:1,name:'xxx',age:18...   xx:1,x1:1},
    {id:2,name:'xxx',age:11...   xx:2,x1:2},
    {id:3,name:'xxx',age:99,     xx:3,x1:3},
2.2.3 read_only
添加时不要,查看时候需要。
需求:编写两个接口 添加(3字段)、获取列表(5个字段)
    # phone = serializers.CharField(source='phone',read_only=True)
    # email = serializers.CharField(source='email',read_only=True)
    class Meta:
        model = models.News
        fields = "__all__"
        read_only_fields = ['phone','email',]
class NewTestView(CreateAPIView, ListAPIView):
添加:
        gender:1
获取:
        {name:'xx',age:'xx',gender:'',phone:'xx',email:xxx}
2.3.4 复杂需求
添加时用一个serializers、列表时用一个serializers
class NewTestModelSerializer1(serializers.ModelSerializer):
    class Meta:
        model = models.News
        fields = "__all__"
class NewTestModelSerializer2(serializers.ModelSerializer):
    class Meta:
        model = models.News
        fields = "__all__"
	def get_serializer_class(self):
        if self.request.method == 'POST':
            return NewTestModelSerializer1
        if self.request.method == 'GET':
            return NewTestModelSerializer2
2.3.5 serializers嵌套
class CreateNewsTopicModelSerializer(serializers.Serializer):
class CreateNewsModelSerializer(serializers.ModelSerializer):
    imageList = CreateNewsTopicModelSerializer(many=True)
    class Meta:
        model = models.News
        exclude = ['user', 'viewer_count', 'comment_count',"favor_count"]
    def create(self, validated_data):
        # 把imageList切走
        image_list = validated_data.pop('imageList')
        # 创建New表中的数据
        news_object = models.News.objects.create(**validated_data)
        data_list = models.NewsDetail.objects.bulk_create(
            [models.NewsDetail(**info, news=news_object) for info in image_list]
        news_object.imageList = data_list
        if news_object.topic:
            news_object.topic.count += 1
            news_object.save()
        return news_object
    发布动态
    serializer_class = CreateNewsModelSerializer
        # 只能保存:News表中的数据()
        # 调用serializer对象的save(先调用create)
        new_object = serializer.save(user_id=1)
        return new_object
3. 首页展示
  • 小程序
    • 初始化
    • 下拉刷新
    • 上翻页
    • 瀑布流
  • 后端API
    • APIView
    • ListAPIView
      • filter
      • pagination
扩展:分页的优化
记录最大值和最小值,防止切片全部数据扫描的问题。
4.详细页面(3点)
  • 写脚本构造数据
  • 最近的访客
  • 一级评论
作业
  1. 赞文章
  2. 赞评论
  3. 关注
  4. 访问记录
    进入详细页面时,先判断用户是否已经登录。
    未登录,不操作。
    登录:添加到访问记录中。
