分布式锁实战
小白弟弟 发表于 2022/01/01 12:29:18 2022/01/01
【摘要】 1、乐观锁,悲观锁乐观锁:版本号,也就是version字段;时间戳 AtomicInteger相关类悲观锁:for update 对标单体的Synchronized,ReentrantLock 2、Redis分布式锁(setnx+lua)自动释放锁pom <dependency> <groupId>org.springframework.boot</group...
1、乐观锁,悲观锁
pom
 <dependency>
    <artifactId>spring-boot-starter-data-redis</artifactId>
		<version>2.1.7.RELEASE</version>
</dependency>
application.properties
spring.redis.host=localhost
spring.redis.password=123456
工具类
import lombok.extern.slf4j.Slf4j;
import org.springframework.data.redis.connection.RedisStringCommands;
import org.springframework.data.redis.core.RedisCallback;
import org.springframework.data.redis.core.RedisTemplate;
import org.springframework.data.redis.core.script.RedisScript;
import org.springframework.data.redis.core.types.Expiration;
import java.util.Arrays;
import java.util.List;
import java.util.UUID;
@Slf4j
public class RedisLock implements AutoCloseable {
    private RedisTemplate redisTemplate;
    private String key;
    private String value;
    //单位:秒
    private int expireTime;
    public RedisLock(RedisTemplate redisTemplate,String key,int expireTime){
        this.redisTemplate = redisTemplate;
        this.key = key;
        this.expireTime=expireTime;
        this.value = UUID.randomUUID().toString();
     * 获取分布式锁
     * @return
    public boolean getLock(){
        RedisCallback<Boolean> redisCallback = connection -> {
            //设置NX
            RedisStringCommands.SetOption setOption = RedisStringCommands.SetOption.ifAbsent();
            //设置过期时间
            Expiration expiration = Expiration.seconds(expireTime);
            //序列化key
            byte[] redisKey = redisTemplate.getKeySerializer().serialize(key);
            //序列化value
            byte[] redisValue = redisTemplate.getValueSerializer().serialize(value);
            //执行setnx操作
            Boolean result = connection.set(redisKey, redisValue, expiration, setOption);
            return result;
        //获取分布式锁
        Boolean lock = (Boolean)redisTemplate.execute(redisCallback);
        return lock;
    public boolean unLock() {
        String script = "if redis.call(\"get\",KEYS[1]) == ARGV[1] then\n" +
                "    return redis.call(\"del\",KEYS[1])\n" +
                "else\n" +
                "    return 0\n" +
                "end";
        RedisScript<Boolean> redisScript = RedisScript.of(script,Boolean.class);
        List<String> keys = Arrays.asList(key);
        Boolean result = (Boolean)redisTemplate.execute(redisScript, keys, value);
        log.info("释放锁的结果:"+result);
        return result;
    @Override
    public void close() throws Exception {
        unLock();
加锁
@Autowired
    @RequestMapping("redisLock")
    public String redisLock(){
        log.info("我进入了方法!");
        try (RedisLock redisLock = new RedisLock(redisTemplate,"redisKey",30)){
            if (redisLock.getLock()) {
                log.info("我进入了锁!!");
                Thread.sleep(15000);
        } catch (InterruptedException e) {
            e.printStackTrace();
        } catch (Exception e) {
        log.info("方法执行完成");
        return "方法执行完成";
3、Zookeeper实现分布式锁
pom
<dependency>
		<groupId>org.apache.zookeeper</groupId>
		<artifactId>zookeeper</artifactId>
		<version>3.4.14</version>
<dependency>
工具类(自动释放锁)
import org.apache.zookeeper.*;
import org.apache.zookeeper.data.Stat;
import java.io.IOException;
import java.util.Collections;
@Slf4j
public class ZkLock implements AutoCloseable, Watcher {
    private ZooKeeper zooKeeper;
    private String znode;
    public ZkLock() throws IOException {
        this.zooKeeper = new ZooKeeper("localhost:2181",
                10000,this);
    public boolean getLock(String businessCode) {
        try {
            //创建业务 根节点
            Stat stat = zooKeeper.exists("/" + businessCode, false);
            if (stat==null){
                zooKeeper.create("/" + businessCode,businessCode.getBytes(),
                        ZooDefs.Ids.OPEN_ACL_UNSAFE,
                        CreateMode.PERSISTENT);
            //创建瞬时有序节点  /order/order_00000001
            znode = zooKeeper.create("/" + businessCode + "/" + businessCode + "_", businessCode.getBytes(),
                    CreateMode.EPHEMERAL_SEQUENTIAL);
            //获取业务节点下 所有的子节点
            List<String> childrenNodes = zooKeeper.getChildren("/" + businessCode, false);
            //子节点排序
            Collections.sort(childrenNodes);
            //获取序号最小的(第一个)子节点
            String firstNode = childrenNodes.get(0);
            //如果创建的节点是第一个子节点,则获得锁
            if (znode.endsWith(firstNode)){
                return true;
            //不是第一个子节点,则监听前一个节点
            String lastNode = firstNode;
            for (String node:childrenNodes){
                if (znode.endsWith(node)){
                    zooKeeper.exists("/"+businessCode+"/"+lastNode,true);
                    break;
                }else {
                    lastNode = node;
            synchronized (this){
                wait();
            return true;
        return false;
    @Override
        zooKeeper.delete(znode,-1);
        zooKeeper.close();
        log.info("我已经释放了锁!");
    @Override
    public void process(WatchedEvent event) {
        if (event.getType() == Event.EventType.NodeDeleted){
                notify();
代码实现:
 @RequestMapping("zkLock")
    public String zookeeperLock(){
        try (ZkLock zkLock = new ZkLock()) {
            if (zkLock.getLock("order")){
                log.info("我获得了锁");
                Thread.sleep(10000);
        } catch (IOException e) {
        log.info("方法执行完成!");
        return "方法执行完成!";
4、Zookeeper的Curator实现分布式锁
pom
<dependency>
    </dependency>
    <dependency>
        <groupId>org.apache.curator</groupId>
        <artifactId>curator-recipes</artifactId>
        <version>4.2.0</version>
    </dependency>
实例化对象
 @Bean(initMethod="start",destroyMethod = "close")
    public CuratorFramework getCuratorFramework() {
        RetryPolicy retryPolicy = new ExponentialBackoffRetry(1000, 3);
        CuratorFramework client = CuratorFrameworkFactory.newClient("localhost:2181", retryPolicy);
        return client;
代码实现
  @Autowired
    private CuratorFramework client;
    @RequestMapping("curatorLock")
    public String curatorLock(){
        InterProcessMutex lock = new InterProcessMutex(client, "/order");
        try{
            if (lock.acquire(30, TimeUnit.SECONDS)){
                log.info("我获得了锁!!");
        }finally {
            try {
                log.info("我释放了锁!!");
                lock.release();
        return "方法执行完成!";
5、Spring集成Redisson原生
pom
<dependency>
   <groupId>org.redisson</groupId>
   <artifactId>redisson</artifactId>
   <version>3.16.7</version>
</dependency>
配置类
@Bean
    public RedissonClient redissonClient(){
        Config config=new Config();
        config.useSingleServer().setAddress("redis://192.168.73.130:6379");
        return Redisson.create(config);
使用
//引用
@Autowired
private RedissonClient redisson;
//代码中使用
		RLock rLock = redisson.getLock("order");
        try {
            rLock.lock(30, TimeUnit.SECONDS);
            log.info("我获得了锁!!!");
        }finally {
            rLock.unlock();
6、SpringBoot集成Redisson
pom
<dependency>
        <artifactId>redisson-spring-boot-starter</artifactId>
        <version>3.13.6</version>
    </dependency>
添加:redisson.xml文件
<beans xmlns="http://www.springframework.org/schema/beans"
       xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
       xmlns:context="http://www.springframework.org/schema/context"
       xmlns:redisson="http://redisson.org/schema/redisson"
       xsi:schemaLocation="
       http://www.springframework.org/schema/beans/spring-beans.xsd
       http://www.springframework.org/schema/context/spring-context.xsd
       http://redisson.org/schema/redisson/redisson.xsd
    <redisson:client>
        <redisson:single-server address="redis://localhost:6379"/>
    </redisson:client>
</beans>
启动类中添加
@ImportResource("classpath:redisson.xml")*
代码中使用
@Autowired
    @RequestMapping("redissonLock")
    public String redissonLock() {
        log.info("我进入了方法!!");
        try {
        }finally {
            rLock.unlock();
        log.info("方法执行完成!!");
        return "方法执行完成!!";
下面是本人的公众号:(有兴趣可以扫一下,文章会同步过去)
我是小白弟弟,一个在互联网行业的小白,立志成为一名架构师
https://blog.csdn.net/zhouhengzhe?t=1
