rageframe(PHP微擎)树分类(curd)
陈业贵 发表于 2021/12/31 23:04:19 2021/12/31
【摘要】 sql: 控制器: <?php namespace frontend\controllers; use app\models\ShopCategory; use yii\web\Controll...
sql:
控制器:
<?php
use yii\web\Controller;
use Yii;
class CygController extends Controller
    public function actionList()
        $model = new ShopCategory;
        //获取列表
        $cates = $model->getTreeList();
        return $this->render("cates", ['cates' => $cates]);
    public function actionAdd()
        $model = new ShopCategory();
        $list = $model->getOptions();
        if (Yii::$app->request->isPost) {
            $post = Yii::$app->request->post();
            if ($model->add($post)) {
                Yii::$app->session->setFlash("info", "添加成功");
        return $this->render("add", ['list' => $list, 'model' => $model]);
    public function actionMod()
        $cateid = Yii::$app->request->get("cateid");
        $model = ShopCategory::find()->where('cateid = :id', [':id' => $cateid])->one();
            if ($model->load($post) && $model->save()) {
                Yii::$app->session->setFlash('info', '修改成功');
        return $this->render('add', ['model' => $model, 'list' => $list]);
    public function actionDel()
        try {
            $cateid = Yii::$app->request->get('cateid');
            if (empty($cateid)) {
                throw new \Exception('参数错误');
            $data = ShopCategory::find()->where('parentid = :pid', [":pid" => $cateid])->one();
            if ($data) {
                throw new \Exception('该分类下有子类,不允许删除');
            if (!ShopCategory::deleteAll('cateid = :id', [":id" => $cateid])) {
                throw new \Exception('删除失败');
        } catch(\Exception $e) {
            Yii::$app->session->setFlash('info', $e->getMessage());
        return $this->redirect(['cyg/list']);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
model:
<?php
namespace app\models;
use yii\db\ActiveRecord;
use Yii;
use yii\helpers\ArrayHelper;
 * This is the model class for table "shop_category".
 * @property string $cateid
 * @property string $title
 * @property string $parentid
 * @property int $createtime
class ShopCategory extends \yii\db\ActiveRecord
     * {@inheritdoc}
    public static function tableName()
        return 'shop_category';
     * {@inheritdoc}
    public function rules()
        return [
            [['parentid', 'createtime'], 'integer'],
            [['title'], 'string', 'max' => 32],
     * {@inheritdoc}
    public function attributeLabels()
        return [
            'cateid' => 'Cateid',
            'title' => 'Title',
            'parentid' => 'Parentid',
            'createtime' => 'Createtime',
    public function add($data)
        $data['ShopCategory']['createtime'] = time();
        if ($this->load($data) && $this->save()) {
            return true;
        return false;
    public function getData()
    {//获取sopcategory类的数据
        $cates = self::find()->all();
        //列成数组
        $cates = ArrayHelper::toArray($cates);
        return $cates;//返回
    public function getTree($cates, $pid = 0)//获取树的子类
        $tree = [];
        foreach($cates as $cate) {
            if ($cate['parentid'] == $pid) {//如果是顶级分类的话.
                $tree[] = $cate;//就把顶级分类放到里面,以次内推.....
                $tree = array_merge($tree, $this->getTree($cates, $cate['cateid']));//继续递归调用自己,意思是
                //比如新闻
        return $tree;
    public function setPrefix($data, $p = "|-----")
        var_dump($data);
        $tree = [];
        $num = 1;
        $prefix = [0 => 1];
        while($val = current($data)) {
            $key = key($data);//key开始在0的位置
            if ($key > 0) {//从第二个开始
                if ($data[$key - 1]['parentid'] != $val['parentid']) {
                    $num ++;
            if (array_key_exists($val['parentid'], $prefix)) {
                $num = $prefix[$val['parentid']];
            $val['title'] = str_repeat($p, $num).$val['title'];
            $prefix[$val['parentid']] = $num;
            $tree[] = $val;
            next($data);
        return $tree;
    public function getOptions()
        $data = $this->getData();
        $tree = $this->getTree($data);
        $tree = $this->setPrefix($tree);
        $options = ['添加顶级分类'];
        foreach($tree as $cate) {
            $options[$cate['cateid']] = $cate['title'];
        return $options;
    public function getTreeList()
        return $tree = $this->setPrefix($tree);
    public static function getMenu()
        $top = self::find()->where('parentid = :pid', [":pid" => 0])->limit(11)->orderby('createtime asc')->asArray()->all();
        $data = [];
        foreach((array)$top as $k=>$cate) {
            $cate['children'] = self::find()->where("parentid = :pid", [":pid" => $cate['cateid']])->limit(10)->asArray()->all();
            $data[$k] = $cate;
        return $data;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
视图:add.php
<?php
    use yii\bootstrap\ActiveForm;
    use yii\helpers\Html;
    <link rel="stylesheet" href="assets/admin/css/compiled/new-user.css" type="text/css" media="screen" />
    <!-- main container -->
    <div class="content">
        <div class="container-fluid">
            <div id="pad-wrapper" class="new-user">
                <div class="row-fluid header">
                    <h3>添加新分类</h3>
                </div>
                <div class="row-fluid form-wrapper">
                    <!-- left column -->
                    <div class="span9 with-sidebar">
                        <div class="container">
                                <?php
                                if (Yii::$app->session->hasFlash('info')) {
                                    echo Yii::$app->session->getFlash('info');
                                $form = ActiveForm::begin([
                                    'fieldConfig' => [
                                        'template' => '<div class="span12 field-box">{label}{input}</div>{error}',
                                    'options' => [
                                        'class' => 'new_user_form inline-input',
                                echo $form->field($model, 'parentid')->dropDownList($list);
                                echo $form->field($model, 'title')->textInput(['class' => 'span9']);
                                <div class="span11 field-box actions">
                                    <?php echo Html::submitButton('添加', ['class' => 'btn-glow primary']);?>
                                    <span>OR</span>
                                    <?php echo Html::resetButton('取消', ['class' => 'reset']); ?>
                                    <?php echo Html::a('返回', ['cyg/list'], ['class' => 'btn btn-primary fanhui']);?>
                                </div>
                            <?php ActiveForm::end(); ?>
                        </div>
                    </div>
                    <!-- side right column -->
                </div>
            </div>
        </div>
    </div>
    <!-- end main container -->
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
cates.php
  <link rel="stylesheet" href="assets/admin/css/compiled/user-list.css" type="text/css" media="screen" />
            <div id="pad-wrapper" class="users-list">
                    <h3>分类列表</h3>
                    <div class="span10 pull-right">
                        <a href="<?php echo yii\helpers\Url::to(['cyg/add']) ?>" class="btn-flat success pull-right">
                            <span>&#43;</span>
                            添加新分类
                        </a>
                    </div>
                </div>
                    <?php
                <!-- Users table -->
                <div class="row-fluid table">
                    <table class="table table-hover">
                        <thead>
                            <tr>
                                <th class="span3 sortable">
                                    <span class="line"></span>分类ID
                                </th>
                                    <span class="line"></span>分类名称
                                </th>
                                <th class="span3 sortable align-right">
                                    <span class="line"></span>操作
                                </th>
                            </tr>
                        </thead>
                        <tbody>
                        <!-- row -->
                        <?php foreach($cates as $cate): ?>
                        <tr class="first">
                            <td>
                                <?php echo $cate['cateid'] ?>
                            </td>
                            <td>
                                <?php echo $cate['title'] ; ?>
                            </td>
                            <td class="align-right">
                            <a href="<?php echo yii\helpers\Url::to(['cyg/mod', 'cateid' => $cate['cateid']]); ?>">编辑</a>
                            <a href="<?php echo yii\helpers\Url::to(['cyg/del', 'cateid' => $cate['cateid']]); ?>">删除</a>
                            </td>
                        </tr>
                        <?php endforeach; ?>
                        </tbody>
                    </table>
                </div>
                <div class="pagination pull-right">
                    <?php /*echo yii\widgets\LinkPager::widget([
                        'pagination' => $pager,
                        'prevPageLabel' => '&#8249;',
                        'nextPageLabel' => '&#8250;',
                </div>
                <!-- end users table -->
            </div>
        </div>
    </div>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
结构:在这里插入图片描述
效果图
文章来源: blog.csdn.net,作者:贵哥的编程之路(喜欢分享),版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_37805832/article/details/122242478
