深入Python(1): 字典排序 关于sort()、reversed()、sorted()、cmp()等
格图洛书 发表于 2021/12/31 22:13:18 2021/12/31
【摘要】 一、最不沾边的cmp() cmp(x, y) Compare the two objects x and y and return an integer according to the outcome. The return value is negative if x < y, zero if...
一、最不沾边的cmp()
cmp(x, y)
Compare the two objects x and y and return an integer according to the outcome. The return value is negative if x < y, zero if x == y and strictly positive if x > y.
如:
文章来源: wenyusuran.blog.csdn.net,作者:文宇肃然,版权归原作者所有,如需转载,请联系作者。
原文链接:wenyusuran.blog.csdn.net/article/details/25289711
