最速梯度法和牛顿法的步长的算法
格图洛书 发表于 2022/01/01 00:19:14 2022/01/01
【摘要】 % Program: inex_lsearch.m% Title: Inexact Line Search% Description: Implements Fletcher's inexact line search described in% Algorithm 4.6.% Theory: See Practical Op...
  1. % Program: inex_lsearch.m
  2. % Title: Inexact Line Search
  3. % Description: Implements Fletcher's inexact line search described in
  4. % Algorithm 4.6.
  5. % Theory: See Practical Optimization Sec. 4.8
  6. % Input:
  7. % x: initial point
  8. % s: search direction
  9. % F: objective function to be minimized along the direction of s
  10. % G: gradient of objective function F
  11. % p1: internal parameters that are required for the implementation of
  12. % the line search regardless of the application at hand.
  13. % It is a string (e.g. 'rho = 0.1') and can be a combination several
  14. % internal parameters (e.g., 'rho = 0.25; sigma=0.5').
  15. % Useful p1's include: default value
  16. % 'rho= ' defines right bracket 0.1
  17. % 'sigma= ' defines left bracket (sigma >= rho) 0.1
  18. % 'tau= ' defines minimum step for se
文章来源: wenyusuran.blog.csdn.net,作者:文宇肃然,版权归原作者所有,如需转载,请联系作者。
原文链接:wenyusuran.blog.csdn.net/article/details/43407251
