Ogrekit-Android的常用native方法
ShaderJoy 发表于 2021/12/29 23:43:15 2021/12/29
【摘要】 /** * Declaration for function defined in nv_time/nv_time.cpp It initializes * and returns time through Nvidia's egl extension for time. It is useful * while debugging t...
  1. /**
  2. * Declaration for function defined in nv_time/nv_time.cpp It initializes
  3. * and returns time through Nvidia's egl extension for time. It is useful
  4. * while debugging the demo using PerfHUD.
  5. * * @see: nv_time/nv_time.cpp for implementation details.
  6. */
  7. public native void nvAcquireTimeExtension();
  8. public native long nvGetSystemTime();
  9. public native boolean render(int drawWidth, int drawHeight,boolean forceRedraw);
  10. public native void cleanup();
  11. public native boolean init(String initArg);
  12. public native boolean inputEvent(int action, float x, float y, MotionEvent event);
  13. public native boolean keyEvent(int action, int unicodeChar, int keyCode, KeyEvent event);
  14. public native void setOffsets(int x, int y);
  15. // needs to be implemented yet and called at onPause()-Event
  16. public native void pauseSound();
  17. // needs to be implemented yet and called at onResume()-Event
  18. public native void restartSound();
  19. public native void sendSensor(int sensorType, float x, float y, float z);
  20. public native void sendMessage(String from, String to, String topic, String body);
文章来源: panda1234lee.blog.csdn.net,作者:panda1234lee,版权归原作者所有,如需转载,请联系作者。
原文链接:panda1234lee.blog.csdn.net/article/details/8261937
