OpenCV Error: Unspecified Error(The Function is not implemented)
小麦大叔 发表于 2021/12/30 01:37:50 2021/12/30
【摘要】 Ubuntu 或者 Debian 系统显示窗口的时候遇到了这个问题 error: (-2:Unspecified error) The function is not implemented. Rebu...
error: (-2:Unspecified error) The function is not implemented. Rebuild the library with Windows, GTK+ 2.x or Carbon support. If you are on Ubuntu or Debian, install libgtk2.0-dev and pkg-config, then re-run cmake or configure script in function ‘cvNamedWindow’
##解决办法
apt-get install libgtk2.0-dev pkg-config
安装成功之后,重新运行cmake对源码进行编译,安装。
文章来源: great.blog.csdn.net,作者:小麦大叔,版权归原作者所有,如需转载,请联系作者。
原文链接:great.blog.csdn.net/article/details/81431030
