ARM-Linux Gcc 交叉编译环境搭建
小麦大叔 发表于 2021/12/30 00:27:36 2021/12/30
【摘要】 1 NFS网络文件系统搭建 测试宿主机与目标板ping通 目标板上某个文件夹(例如mnt)挂载到宿主机(192.168.1.111)的/home/nfs_dir文件夹下 mount –t nfs –...
1 NFS网络文件系统搭建
测试宿主机与目标板ping通
mount –t nfs –o nolock 192.168.1.111:/home/nfs_dir /mnt
2 交叉编译环境的搭建
参考http://linux-sunxi.org/Toolchain 通过apt-get可以很简单地安装交叉编译环境
Ubuntu
Recent (from12.04 on)
A complete cross toolchain is available asa package, just run:
apt-get install gcc-arm-linux-gnueabihf
Debian
Details on Cross-development Toolchainsfor Debian are at the DebianWiki.
Note: Debian now hascross-toolchains in the archive, superseding those at emdebian.org
Currently (December 2015) available forunstable and testing in the standard repositories.
Install Cross Compiler and build utilities:
dpkg --add-architecture armhf
apt-get update
apt-get install g++-arm-linux-gnueabihf
安装之后在终端输入 arm 按下tab 并且自动补全之后,输入
arm-linux-gnueabihf-gcc -v
如果安装成功终端会打印出以下信息:
Using built-in specs.
COLLECT_GCC=arm-linux-gnueabihf-gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/arm-linux-gnueabihf/4.7/lto-wrapper
Target: arm-linux-gnueabihf
Configured with: ../src/configure -v--with-pkgversion='Ubuntu/Linaro 4.7.1-5ubuntu1~ppa1'--with-bugurl=file:///usr/share/doc/gcc-4.7/README.Bugs--enable-languages=c,c++,go,fortran,objc,obj-c++ --prefix=/usr--program-suffix=-4.7 --enable-shared --enable-linker-build-id--with-system-zlib --libexecdir=/usr/lib --without-included-gettext--enable-threads=posix--with-gxx-include-dir=/usr/arm-linux-gnueabihf/include/c++/4.7.1 --libdir=/usr/lib--enable-nls --enable-clocale=gnu --enable-libstdcxx-debug--enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libitm--enable-plugin --enable-objc-gc --enable-multilib --disable-sjlj-exceptions--with-arch=armv7-a --with-fpu=vfpv3-d16 --with-float=hard --with-mode=thumb--disable-werror --enable-checking=release --build=x86_64-linux-gnu--host=x86_64-linux-gnu --target=arm-linux-gnueabihf --program-prefix=arm-linux-gnueabihf---includedir=/usr/arm-linux-gnueabihf/include--with-headers=/usr/arm-linux-gnueabihf/include--with-libs=/usr/arm-linux-gnueabihf/lib
Thread model: posix
gcc version 4.7.1 (Ubuntu/Linaro4.7.1-5ubuntu1~ppa1)
3 环境变量
apt-get方式进行安装已经配置好了环境变量,如果自己下载源码编译安装或者直接安装bin文件,则还需要设置环境变量(链接)
vi /etc/bash.bashrc
export PATH=$PATH:编译器安装路径
source /root/.bashrc
安装完交叉编译器,就可以生成目标板的可执行程序
遇到以下问题
1 运行程序时提示“-sh: ./pl: not found”
解决办法
目标板上没有运行程序所需要的库,查看所需要的库的方法
readelf -ahello | grep NEEDED
最后终端会打印出该程序执行的依赖库,将相应的库拷贝的lib文件夹下即可。
注意:该依赖库需要使用相同版本的交叉编译器
解决方法:
方法1、 把这些所需要的库拷贝到板子上,保证板子上找得到。
方法2、 编译的时候使用静态编译,arm-linux-gcc-o hello hello.c -static
文章来源: great.blog.csdn.net,作者:小麦大叔,版权归原作者所有,如需转载,请联系作者。
原文链接:great.blog.csdn.net/article/details/52497152
