Oracle 重复数据查询以及删除
人工智能-张晨光 发表于 2021/12/29 23:53:41 2021/12/29
【摘要】 视频课:https://edu.csdn.net/course/play/7940 Create table test (id number(2),  names varchar2(20));  insert into test values(1,'张三'); insert into test valu...
Create table test
(id number(2),
 insert into test values(2,'李四');
 insert into test values(3,'马七');
 select * from test;
 --查找重复数据
select * from test a where (a.id,a.names) in
 (select id,names from test group by id,names having count(*) > 1)
 --删除重复数据,只留rowid最小的那行;
 delete from test a where (a.id,a.names) in
  and rowid not in (select min(rowid) from test group by id,names having count(*)>1)
  --查找重复数据,不含rowid最小的行
---1.以上是重复数据根据多列来判断
以下是重复数据根据单列来判断
1、首先,查找表中多余的重复记录,重复记录是根据单个字段(id)来判断
select * from test where id in(select id from test group by having count(id) >1)
2、删除表中多余的重复记录,重复记录是根据单个字段(id)来判断,只留有rowid最小的记录
delete from test where (id) in (select id from test group by id having count(id) >1) and rowid not in (select min(rowid) from test group by id having count(*)>1)
原文链接:aaaedu.blog.csdn.net/article/details/58661838
