OCJP 考试题之七
人工智能-张晨光 发表于 2021/12/29 23:28:54 2021/12/29
【摘要】 OCJP视频课堂,具体讲解:https://edu.csdn.net/course/detail/7811 QUESTION 150 Click the Exhibit button. Given: ClassA a = new ClassA(); a.methodA(); What is the result?  ...
QUESTION 150
A. Compilation fails.
B. ClassC is displayed.
C. The code runs with no output.
D. An exception is thrown at runtime.
Answer: D
问题出在第24行,classC还没有new一个,就直接用函数getValue(),NullPointerException会被抛出
public ClassC classC;该行代码没有new出来ClassC,空指针异常;
QUESTION 151 Given:
11. static void test() throwsRuntimeException {
12. try {
13. System.out.print("test");
14. throw new RuntimeException();
15. }
16. catch (Exception ex) { System.out.print("exception"); }
17. }
18. public static voidmain(String[] args) {
19. try { test(); }
20. catch (RuntimeException ex) {System.out.print("runtime "); }
21. System.out.print("end");
22. }
What is the result?
A.   test end
B.   Compilation fails.
C.   test runtime end
D.   test exception end
E.   A Throwable is thrown by mainat runtime.
Answer: D
QUESTION 152 Given:
1. public class Plant {
2. private String name;
3. public Plant(String name) {this.name = name; }
4. public String getName() { returnname; }
5. }
1. public class Tree extends Plant{
2. public void growFruit() { }
3. public void dropLeaves() { }
4. }
Which statement is true?
A.   The code will compile withoutchanges.
B.   The code will compile if publicTree() { Plant(); } is added to the Tree class.
C.   The code will compile if publicPlant() { Tree(); } is added to the Plant class.
D.   The code willcompile if public Plant() { this("fern"); } is added to the Plantclass.
E.   The code will compile if publicPlant() { Plant("fern"); } is added to the Plant class.
Answer: D
Section: (none)
Plant需要一个无参默认构造函数,因为子类带一个参数的构造函数
QUESTION 153
Given:
10. class Line {
11. public static class Point {}
12. }
13.
14. class Triangle {
15. // insert code here
16. }
Which code, inserted at line 15, createsan instance of the Point class defined in Line?
A.   Point p = new Point();
B.   Line.Point p = newLine.Point();
C.   The Point class cannot beinstatiated at line 15.
D.   Line l = new Line() ; l.Point p= new l.Point();
Answer: B
QUESTION 154 Given:
10. class Nav{
11. public enum Direction { NORTH,SOUTH, EAST, WEST }
12. }
13. public class Sprite{
14. // insert code here
15. }
Which code, inserted at line 14, allowsthe Sprite class to compile?
A.   Direction d = NORTH;
B.   Nav.Direction d = NORTH;
C.   Direction d = Direction.NORTH;
D.   Nav.Direction d = Nav.Direction.NORTH;
Answer: D
Section: (none)
原文链接:aaaedu.blog.csdn.net/article/details/54580558
