myabatis oracle 调用存储过程返回list结果集
人工智能-张晨光 发表于 2021/12/29 23:51:25 2021/12/29
【摘要】 视频课:https://edu.csdn.net/course/play/7940 Mapper.xml 配置   <resultMap type="emp" id="empMap">   <id property="empno" column="empno"/>   &...
Mapper.xml 配置
  <result property="ename" column="ename"/>
  <result property="mgr" column="mgr"/>
  <result property="job" column="job"/>
  <result property="hiredate" column="hiredate"/>
  <result property="sal" column="sal"/>
  <result property="comm" column="comm"/>
 </resultMap>
<!-- 调用存储过程返回结果集 -->
<select id="getEmps" parameterType="java.util.Map" statementType="CALLABLE">
<![CDATA[
call pro_emp(#{emps,mode=OUT,jdbcType=CURSOR,javaType=java.sql.ResultSet,resultMap=empMap})  ]]>
</select>
存储过程:
create or replace procedure pro_emp(cur_sys out sys_refcursor)
as
begin
    open cur_sys for select empno, ename, job, mgr, hiredate, sal, comm, deptno
     from tb_emp;
end;
IOperation接口里的方法 :
public interface IOperation {
void getEmps(Map<String, Object> param);
测试类:
public class Mytest {
private SqlSession sqlSession;
private IOperation mapper;
@Before
public void before(){
try {
SqlSessionFactory factory=MyBatisUtil.getSqlSessionFactory();
sqlSession=factory.openSession();
mapper=sqlSession.getMapper(IOperation.class);
System.out.println("start");
} catch (Exception e) {
System.out.println(e.getMessage());
@Test
public void getEmps(){
try {
   Map<String, Object> param = new HashMap<String, Object>();
       param.put("emps",OracleTypes.CURSOR);
       mapper.getEmps(param);
       List<Emp> depts =(List<Emp>)param.get("emps");
       for (Emp emp : depts) {
System.out.println(emp.getEmpno()+" "+emp.getEname());
System.out.println("getEmp: "+e.getMessage());
 @After
 public void after(){
 System.out.println("close");
 sqlSession.close();
结果:
start
DEBUG - Openning JDBC Connection
DEBUG - Created connection 8344960.
DEBUG - ooo Using Connection [oracle.jdbc.driver.T4CConnection@7f5580]
DEBUG - ==>  Preparing: call pro_emp(?)
DEBUG - ==> Parameters:
123 liuzan
7369 SMITH
7499 ALLEN
7521 WARD
7566 JONES
7654 MARTIN
7698 BLAKE
7782 CLARK
7788 SCOTT
7839 KING
7844 TURNER
7876 ADAMS
7900 JAMES
7902 FORD
7934 MILLER
close
原文链接:aaaedu.blog.csdn.net/article/details/59152156
