Spring整合mybatis 1 查询
【摘要】
框架如图:
web.xml文件代码
<?xml version="1.0" encoding="UTF-8"?><web-app version="2.5" xmlns="http://java.sun.com/xml/ns/javaee" xmlns:xsi="http://www.w3.org/2001/X...
框架如图:
web.xml文件代码
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://java.sun.com/xml/ns/javaee
http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd">
<!-- 1.spring监听 -->
<context-param>
<param-name>contextConfigLocation</param-name>
<param-value>/WEB-INF/spring-mybatis.xml</param-value>
</context-param>
<!--spring-->
<listener>
<listener-class>org.springframework.web.context.ContextLoaderListener</listener-class>
</listener>
<!-- 2.springmvc -->
<servlet>
<servlet-name>springmvc</servlet-name>
<servlet-class> org.springframework.web.servlet.DispatcherServlet</servlet-class>
<init-param>
<param-value>/WEB-INF/spring-mvc.xml</param-value>
</init-param>
</servlet>
<servlet-mapping>
<url-pattern>/</url-pattern>
</servlet-mapping>
<!-- 3.字符编码处理 -->
<filter>
<filter-name>encodingFilter</filter-name>
<filter-class>org.springframework.web.filter.CharacterEncodingFilter</filter-class>
<init-param>
<param-name>encoding</param-name>
<param-value>UTF-8</param-value>
</init-param>
</filter>
<filter-mapping>
<url-pattern>/*</url-pattern>
</filter-mapping>
</web-app>
<beans xmlns="http://www.springframework.org/schema/beans"
xmlns:p="http://www.springframework.org/schema/p"
xmlns:context="http://www.springframework.org/schema/context"
xmlns:mvc="http://www.springframework.org/schema/mvc"
http://www.springframework.org/schema/beans/spring-beans-3.0.xsd
http://www.springframework.org/schema/context/spring-context-3.0.xsd
http://www.springframework.org/schema/mvc/spring-mvc-3.0.xsd
<!-- 默认扫描包路径,扫描控制器 -->
<context:component-scan base-package="com.controller"></context:component-scan>
<!-- 注解驱动 -->
<mvc:annotation-driven/>
<!-- 视图解析器 -->
<bean id="viewResolver" class="org.springframework.web.servlet.view.InternalResourceViewResolver">
<property name="prefix" value="/" />
<property name="suffix" value=".jsp" />
</bean>
</beans>
<beans
xsi:schemaLocation="http://www.springframework.org/schema/beans
http://www.springframework.org/schema/context/spring-context-3.0.xsd">
<!-- 1.自动扫描 -->
<context:component-scan base-package="com"></context:component-scan>
<!-- 2.配置数据源,就是原来mybatis的代码,此处使用dbcp数据源连接池 -->
<bean id="datasource" class="org.apache.commons.dbcp.BasicDataSource">
<property name="driverClassName" value="oracle.jdbc.OracleDriver"/>
<property name="url" value="jdbc:oracle:thin:@192.168.62.250:1521:orcl"/>
<property name="username" value="scott"/>
<property name="password" value="tiger"/>
</bean>
<!-- 3.配置sqlSessionFactory -->
<bean id="sqlSessionFactory" class="org.mybatis.spring.SqlSessionFactoryBean">
<property name="dataSource" ref="datasource"/><!-- 数据源连接池 -->
<property name="mapperLocations" value="classpath:com/mapper/*.xml"></property>
</bean>
<!-- 4.mapper扫描器 -->
<bean class="org.mybatis.spring.mapper.MapperScannerConfigurer">
<property name="basePackage" value="com.dao"/>
<property name="sqlSessionFactoryBeanName" value="sqlSessionFactory"/>
</bean>
</beans>
实体类,Emp类
package com.entity;
public class Emp {
private int empNo;
private String eName;
private String salary;
public int getEmpNo() {
return empNo;
public void setEmpNo(int empNo) {
this.empNo = empNo;
public String geteName() {
return eName;
public void seteName(String eName) {
this.eName = eName;
public String getSalary() {
return salary;
public void setSalary(String salary) {
this.salary = salary;
package com.dao;
import java.util.List;
import java.util.Map;
import com.entity.Emp;
public interface EmpDao {
public List<Emp> search();
<!DOCTYPE mapper PUBLIC "-//mybatis.org//DTD Mapper 3.0//EN"
"http://mybatis.org/dtd/mybatis-3-mapper.dtd">
<mapper namespace="com.dao.EmpDao">
<select id="search" resultType="com.entity.Emp">
select empno ,ename , sal from emp
</select>
</mapper>
package com.service;
public interface IEmpService {
List<Emp> getList();
package com.service.impl;
import javax.annotation.Resource;
import org.springframework.stereotype.Component;
import com.dao.EmpDao;
import com.service.IEmpService;
@Component
public class EmpServiceImpl implements IEmpService{
@Resource
private EmpDao empDao;
public List<Emp> getList() {
return empDao.search();
package com.controller;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.stereotype.Controller;
import org.springframework.ui.Model;
import org.springframework.web.bind.annotation.RequestMapping;
@Controller
@RequestMapping("/emp")
public class EmpController {
@Resource
private IEmpService service;
@RequestMapping("/list")
public String toIndex(Model model){
List<Emp> emps=service.getList();
System.out.println(emps.size()+".......");
model.addAttribute("eno", emps.size());
model.addAttribute("empList", emps);
return "list";
<%@ page language="java" import="java.util.*" pageEncoding="utf-8"%>
<%@ taglib prefix="c" uri="http://java.sun.com/jsp/jstl/core" %>
String path = request.getContextPath();
String basePath = request.getScheme()+"://"+request.getServerName()+":"+request.getServerPort()+path+"/";
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<base href="<%=basePath%>">
<title>My JSP 'index.jsp' starting page</title>
<meta http-equiv="pragma" content="no-cache">
<meta http-equiv="cache-control" content="no-cache">
<meta http-equiv="expires" content="0">
<meta http-equiv="keywords" content="keyword1,keyword2,keyword3">
<meta http-equiv="description" content="This is my page">
</head>
<body>ddd
${eno }
<c:forEach items="${empList}" var="emp">
${emp.eName} <br/>
</c:forEach>
</body>
</html>
原文链接:aaaedu.blog.csdn.net/article/details/70176844
cloudbbs@huaweicloud.com
