OCJP试题分析第一章
人工智能-张晨光 发表于 2021/12/30 00:25:59 2021/12/30
【摘要】 视频 https://edu.csdn.net/course/play/7811 Exam A QUESTION 1 Given a pre-generics implementation of a method: 11. public static int sum(List list) { 12. int sum = 0; 13....
Exam A
QUESTION 1
12. int sum = 0;
13. for ( Iterator iter = list.iterator(); iter.hasNext(); ) {
14. int i = ((Integer)iter.next()).intValue();
15. sum += i;
16. }
17. return sum;
18. }
What three changes allow the class to be used with generics and avoid an unchecked warning? (Choose
three.)
更改哪三处允许这个类使用泛型和避免一个不受检查警告
A. Remove line 14.
B. Replace line 14 with "int i = iter.next();".
C. Replace line 13 with "for (int i : intList) {".
D. Replace line 13 with "for (Iterator iter : intList) {".
E. Replace the method declaration with "sum(List<int> intList)".
F. Replace the method declaration with "sum(List<Integer> intList)".
Answer: ACF
随题分析:注意,此处的题意是要更改三处,而不影响程序的警告,同时更改,切记切记!!!
QUESTION 2
A programmer has an algorithm that requires a java.util.List that provides an efficient implementation of
add(0, object), but does NOT need to support quick random access. What supports these requirements?
翻译:程序员有一个算法要求一个java.util.List 提供一个能有效实施add(0, object),但并不需要支持快速的随机访问。是什么支持这些要求呢?
A. java.util.Queue
B. java.util.ArrayList
C. java.util.LinearList
D. java.util.LinkedList
Answer: D
Queue(队列),没有add()方法。
ArrayList类,有add(0,object)的方法,支持随机访问(random access)
 LinearList没有这样的东东
LinkedList:链表;链表需要从begin()遍历到end(),复杂度是O(n);随机访问的是ArrayList
public class LinkedList<E>
extends AbstractSequentialList<E>
implements List<E>, Queue<E>, Cloneable, java.io.Serializable
此类实现 Queue 接口,为 add、poll 等提供先进先出队列操作。
QUESTION 3
Given:
11. // insert code here
12. private N min, max;
13. public N getMin() { return min; }
14. public N getMax() { return max; }
15. public void add(N added) {
16. if (min == null || added.doubleValue() < min.doubleValue())
17. min = added;
18. if (max == null || added.doubleValue() > max.doubleValue())
19. max = added;
20. }
21. }
Which two, inserted at line 11, will allow the code to compile? (Choose two.)
有哪两项,在11行插入代码,可以将代码进行编译?
A. public class MinMax<?> {
B. public class MinMax<? extends Number> {
C. public class MinMax<N extends Object> {
D. public class MinMax<N extends Number> {
E. public class MinMax<? extends Object> {
F. public class MinMax<N extends Integer> {
Answer: DF
12行代码,定义的变量min,max,方法doubleValue(),可以知道min和max是抽象类Number或其子类的实例化对象。
Number抽象类,所具有的方法如下:
QUESTION 4
Given:
12. import java.util.*;
13. public class Explorer2 {
14. public static void main(String[] args) {
15. TreeSet<Integer> s = new TreeSet<Integer>();
16. TreeSet<Integer> subs = new TreeSet<Integer>();
17. for(int i = 606; i < 613; i++)
18. if(i%2 == 0) s.add(i);
19. subs = (TreeSet)s.subSet(608, true, 611, true);
20. s.add(629);
21. System.out.println(s + " " + subs);
22. }
23. }
What is the result?
A. Compilation fails.
B. An exception is thrown at runtime.
C. [608, 610, 612, 629] [608, 610]
D. [608, 610, 612, 629] [608, 610, 629]
E. [606, 608, 610, 612, 629] [608, 610]
F. [606, 608, 610, 612, 629] [608, 610, 629]
Answer: E
本题主要考查:
1、TreeSet 自然排序
2、subSet()方法的运用
如果同学,你连TreeSet是个啥都不懂,需要下去恶补TreeSet方面的技术点。
有同学,可能会问这啥意思呢?
在循环中,18行代码,s的值是[606,608,610,612],最后在20行代码处又加了629,所以最后s存储的值为[606,608,610,612,629]
排除法就是E。
      返回此 set 的部分视图,其元素从 fromElement(包括)到 toElement(不包括)。(如果 fromElement 与 toElement 相等,则返回的已排序 set 为空。)返回的已排序 set 受此 set 支持,所以在返回的已排序 set 中的更改将在此 set 中得到反映,反之亦然。返回的已排序 set 支持所有可选 Set 操作。
如果用户试图插入指定范围之外的元素,那么由此方法返回的已排序 set 将抛出 IllegalArgumentException。
19行代码,给subs这个TreeSet对象赋值,subSet()方法,类似于String的截取字符串,这里是取部分tree,true表示包含元素节点,false表示不包含元素节点。因为是包含节点,所以,subs为[608,610]。
QUESTION 5
Given:
1. public class Score implements Comparable<Score> {
2. private int wins, losses;
3. public Score(int w, int l) { wins = w; losses = l; }
4. public int getWins() { return wins; }
5. public int getLosses() { return losses; }
6. public String toString() {
7. return "<" + wins + "," + losses + ">";
8. }
9. // insert code here
10. }
Which method will complete this class?
下列哪个方法可以在第9行补充完此类
A. public int compareTo(Object o){/*more code here*/}
B. public int compareTo(Score other){/*more code here*/}
C. public int compare(Score s1,Score s2){/*more code here*/}
D. public int compare(Object o1,Object o2){/*more code here*/}
Answer: B
  1. /**
  2. * Comparable接口实现;
  3. * @author 张晨光
  4. *
  5. */
  6. public class Score implements Comparable<Score>{
  7. //wins:胜利;lossess:损失(损耗)
  8. private int wins,losses;
  9. public Score(int w,int l){wins=w;losses=l;}
  10. public int getWins(){return wins;}
  11. public int getLosses(){return losses;}
  12. public String toString(){
  13. return "<"+wins+","+losses+">";
  14. }
  15. @Override
  16. public int compareTo(Score o) {
  17. return 0;
  18. }
  19. }
public interface Comparable<T>
此接口强行对实现它的每个类的对象进行整体排序。此排序被称为该类的自然排序,类的 compareTo 方法被称为它的自然比较方法。Comparabale接口需要实现compareTo方法泛型是Score
compareTo就是比较两个值,如果前者大于后者,返回1,等于返回0,小于返回-1
不管这个接口还是compartor,都需要和泛型参数保持一致,如下图:
另外一个比较接口:
原文链接:aaaedu.blog.csdn.net/article/details/79927577
