ssm整合之七 事务以及404页面处理
人工智能-张晨光 发表于 2021/12/29 22:58:43 2021/12/29
【摘要】 1  采用外部配置文件,连接数据库jdbc.properties   jdbc.driver=oracle.jdbc.driver.OracleDriverjdbc.url=jdbc:oracle:thin:@192.168.1.102:1521:orcljdbc.username=scottjdbc.passw...
  1. jdbc.driver=oracle.jdbc.driver.OracleDriver
  2. jdbc.url=jdbc:oracle:thin:@192.168.1.102:1521:orcl
  3. jdbc.username=scott
  4. jdbc.password=tiger
2  配置数据库.xml文件
  1. <?xml version="1.0" encoding="UTF-8"?>
  2. <beans
  3. xmlns="http://www.springframework.org/schema/beans"
  4. xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
  5. xmlns:p="http://www.springframework.org/schema/p"
  6. xmlns:tx="http://www.springframework.org/schema/tx"
  7. xmlns:context="http://www.springframework.org/schema/context"
  8. xsi:schemaLocation="http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans-3.0.xsd
  9. http://www.springframework.org/schema/context http://www.springframework.org/schema/context/spring-context-3.0.xsd
  10. http://www.springframework.org/schema/tx http://www.springframework.org/schema/tx/spring-tx-3.0.xsd">
  11. <!-- 开启包扫描 -->
  12. <context:component-scan base-package="com.service.impl"></context:component-scan>
  13. <!-- 扫描加载jdbc配置文件 -->
  14. <bean class="org.springframework.beans.factory.config.PropertyPlaceholderConfigurer">
  15. <property name="location" value="classpath:jdbc.properties"></property>
  16. </bean>
  17. <!-- 配置数据源 -->
  18. <bean id="dataSource" class="org.apache.commons.dbcp.BasicDataSource">
  19. <property name="driverClassName" value="${jdbc.driver}"></property>
  20. <property name="url" value="${jdbc.url}"></property>
  21. <property name="username" value="${jdbc.username}"></property>
  22. <property name="password" value="${jdbc.password}"></property>
  23. </bean>
  24. <!-- 配置SqlSessionFactory -->
  25. <bean id="sqlSessionFactory" class="org.mybatis.spring.SqlSessionFactoryBean">
  26. <!-- 加载数据源 -->
  27. <property name="dataSource" ref="dataSource"></property>
  28. <!-- 扫描mapper文件 -->
  29. <property name="mapperLocations" value="classpath:com/aaa/ssm/mapper/*.xml"></property>
  30. </bean>
  31. <!-- 开启dao接口扫描 -->
  32. <bean class="org.mybatis.spring.mapper.MapperScannerConfigurer">
  33. <!-- 扫描接口包路径,不需要加classpath,如果多个可以用“,”隔开 -->
  34. <property name="basePackage" value="com.aaa.ssm.dao"></property>
  35. <property name="sqlSessionFactoryBeanName" value="sqlSessionFactory"></property>
  36. </bean>
  37. <!-- 配置事务 -->
  38. <bean id="transactionManager" class="org.springframework.jdbc.datasource.DataSourceTransactionManager">
  39. <!-- 加载数据源 -->
  40. <property name="dataSource" ref="dataSource"></property>
  41. </bean>
  42. <!-- 开启事务扫描 -->
  43. <tx:annotation-driven transaction-manager="transactionManager"/>
  44. </beans>
注意,开启事务扫描的代码,注意需要借助于tx命名空间,<tx:annotation-driven />用于支持事务注解,transaction-manager属性用于指定使用哪个事务管理器。
  1. <!-- 配置事务 -->
  2. <bean id="transactionManager" class="org.springframework.jdbc.datasource.DataSourceTransactionManager">
  3. <!-- 加载数据源 -->
  4. <property name="dataSource" ref="dataSource"></property>
  5. </bean>
  6. <!-- 开启事务扫描 -->
  7. <tx:annotation-driven transaction-manager="transactionManager"/>
事务针对的是
com.service.impl包进行扫描,也就是业务层的实现类扫描,负责管理业务逻辑组件里的业务逻辑方法,只有对业务逻辑方法添加事务管理才有实际意义。对于单个DAO方法,CRUD
增加事务管理,意义不大。
业务层代码
  1. /**
  2. * 部门添加
  3. */
  4. @Transactional
  5. public void add(Dept dept) {
  6. // TODO Auto-generated method stub
  7. dao.add(dept);
  8. System.out.println(1/0);
  9. }
针对1/0除零错,如果不增加事务,dao.add(dept)增加的数据可以插入到数据库,而如果添加了事务处理@Transactional,那么只要报错,则数据不会增加到数据库。主要用在级联更新 或防止操作出异常的情况下。
404页面处理,在web.xml文件里面,增加代码如下:
<!-- 5.jsp配置 -->
 <error-page>
<error-code>404</error-code>
<location>/404.jsp</location>
</error-page>
<welcome-file-list>
<welcome-file>index.jsp</welcome-file>
</welcome-file-list>
在项目里面,增加404.jsp页面即可,这样针对系统中出现了404问题的,可以定向跑到404页面,增加界面友好。
原文链接:aaaedu.blog.csdn.net/article/details/71774916
