python中isdigit()、isdecimal()和isnumeric的区别!
人工智能-张晨光 发表于 2021/12/30 00:19:16 2021/12/30
【摘要】 isdecimal(...) | S.isdecimal() -> bool | | Return True if there are only decimal characters in S, | False otherwise. 翻译:如果S中只有十进制字符,则返回True,否则为F...
  1. isdecimal(...)
  2. | S.isdecimal() -> bool
  3. |
  4. | Return True if there are only decimal characters in S,
  5. | False otherwise.
  6. 翻译:如果S中只有十进制字符,则返回True,否则为False。
  1. isdigit(...)
  2. | S.isdigit() -> bool
  3. |
  4. | Return True if all characters in S are digits
  5. | and there is at least one character in S, False otherwise.
  6. 翻译:如果S中的所有字符都是数字,并且在S中至少有一个字符,则返回True。
  1. isnumeric(...)
  2. | S.isnumeric() -> bool
  3. |
  4. | Return True if there are only numeric characters in S,
  6. 翻译:如果S中只有数字字符,则返回True,否则为False。
  1. 1 s = '123'
  2. 2 print(s.isdigit())
  3. 3 print(s.isdecimal())
  4. 4 print(s.isnumeric())
结果为:
  1. True
  2. True
  3. True
  1. s = b'123'
  2. print(s.isdigit())
  3. #print(s.isdecimal())
  4. #print(s.isnumeric())
结果为: (只有第一个能正常输出,另外两个报属性错误)
True
  1. ---------------------------------------------------------------------------
  2. AttributeError Traceback (most recent call last)
  3. <ipython-input-19-9e3f7cdf9524> in <module>()
  4. 2 print(s.isdigit())
  5. 3 #print(s.isdecimal())
  6. ----> 4 print(s.isnumeric())
  7. AttributeError: 'bytes' object has no attribute 'isnumeric'
  1. s = '123.0'
  3. print(s.isdecimal())
  4. print(s.isnumeric())
  1. False
  2. False
  3. False
  1. s = '三叁'
  1. False
  2. False
  3. True
  1. s = 'Ⅲ'
  1. False
  2. False
  3. True
  4. 总结:
  1. isdigit()
  2. True: Unicode数字,byte数字(单字节),全角数字(双字节)
  3. False: 汉字数字,罗马数字,小数
  4. Error: 无
  5. isdecimal()
  6. True: Unicode数字,全角数字(双字节)
  7. False: 罗马数字,汉字数字,小数
  8. Error: byte数字(单字节)
  1. isnumeric()
  2. True: Unicode数字,全角数字(双字节),罗马数字,汉字数字
  3. False: 小数
  4. Error: byte数字(单字节)
原文链接:aaaedu.blog.csdn.net/article/details/81630631
