通过一个实际例子理解Kubernetes里pod的自动scale - 水平自动伸缩
汪子熙 发表于 2021/12/29 15:39:18 2021/12/29
【摘要】 kubectl scale命令用于程序在负载加重或缩小时进行pod扩容或缩小,我们通过一些实际例子来观察scale命令到底能达到什么效果。命令行创建一个deployment:kubectl run jerry-nginx --image=nginx:1.12.2kubectl get deploy查看刚刚创建的deployment:自动被deployment创建的pod:kubectl ge...
命令行创建一个deployment:
kubectl get pod:
使用下列命令查看生成的deployment明细:
kubectl get deployment jerry-nginx -o yaml
apiVersion: extensions/v1beta1
kind: Deployment
metadata:
annotations:
deployment.kubernetes.io/revision: “1”
creationTimestamp: 2018-11-29T08:29:06Z
generation: 1
labels:
run: jerry-nginx
namespace: part-0110
resourceVersion: “7203445”
selfLink: /apis/extensions/v1beta1/namespaces/part-0110/deployments/jerry-nginx
uid: d5c64f72-f3b0-11e8-b308-a20cb743f347
spec:
progressDeadlineSeconds: 600
replicas: 1
revisionHistoryLimit: 2
selector:
matchLabels:
run: jerry-nginx
strategy:
rollingUpdate:
maxSurge: 25%
maxUnavailable: 25%
type: RollingUpdate
template:
metadata:
creationTimestamp: null
labels:
run: jerry-nginx
spec:
containers:
- image: nginx:1.12.2
imagePullPolicy: IfNotPresent
resources: {}
terminationMessagePath: /dev/termination-log
terminationMessagePolicy: File
dnsPolicy: ClusterFirst
restartPolicy: Always
schedulerName: default-scheduler
securityContext: {}
terminationGracePeriodSeconds: 30
status:
availableReplicas: 1
conditions:
  • lastTransitionTime: 2018-11-29T08:29:07Z
    lastUpdateTime: 2018-11-29T08:29:07Z
    message: Deployment has minimum availability.
    reason: MinimumReplicasAvailable
    status: “True”
    type: Available
  • lastTransitionTime: 2018-11-29T08:29:06Z
    message: ReplicaSet “jerry-nginx-69fd9f6c4” has successfully progressed.
    reason: NewReplicaSetAvailable
    status: “True”
    type: Progressing
    observedGeneration: 1
    readyReplicas: 1
    replicas: 1
    updatedReplicas: 1
另一个有用的命令:
kubectl describe deployment jerry-nginx
Namespace: part-0110
CreationTimestamp: Thu, 29 Nov 2018 16:29:06 +0800
Labels: run=jerry-nginx
Annotations: deployment.kubernetes.io/revision: 1
Selector: run=jerry-nginx
Replicas: 1 desired | 1 updated | 1 total | 1 available | 0 unavailable
StrategyType: RollingUpdate
MinReadySeconds: 0
RollingUpdateStrategy: 25% max unavailable, 25% max surge
Pod Template:
Containers:
jerry-nginx:
Image: nginx:1.12.2
Port: <none>
Host Port: <none>
Environment: <none>
Mounts: <none>
Volumes: <none>
Conditions:
Type Status Reason
Available True MinimumReplicasAvailable
Progressing True NewReplicaSetAvailable
OldReplicaSets: <none>
NewReplicaSet: jerry-nginx-69fd9f6c4 (1/1 replicas created)
Events:
Type Reason Age From Message
Normal ScalingReplicaSet 9m41s deployment-controller Scaled up replica set jerry-nginx-69fd9f6c4 to 1
现在我们使用下面的命令对deployment进行水平扩展:
kubectl scale deployment jerry-nginx --replicas=3
kubectl get pods -l run=jerry-nginx
下图这个Age为15分钟之前的是第一次创建deployment时生成的,其他两个Age为1分钟之前的是执行了scale命令后自动创建的。
选中一个才创建的pod,查看其事件记录:
kubectl describe pod jerry-nginx-69fd9f6c4-8dpvb
kubectl get replicaset
得到自动创建的replication set:
desired = 3意思就是我们水平扩展时指定的参数3.
即使手动删除一个pod实例,replication set又会很快自动创建一个新的:
自动创建的新pod:
在 SAP CCV2 中的应用
if we reduce the replica of jsapps to 1, the issue will be gone?
If so, for a short-term workaround, one option would be to set the jsapps’s replica to 1, and vertically scale it up to have more CPU/memory.
要获取更多Jerry的原创文章,请关注公众号"汪子熙".
