分形:一种计算出来的花朵
tsinghuazhuoqing 发表于 2021/12/26 23:35:51 2021/12/26
【摘要】   01曼德勃罗集合 曼德勃罗集合就是复平面上的点 c c ...
01曼德勃罗集合
曼德勃罗集合就是复平面上的点 c c c,对于下面二次迭代方程收敛。
z n + 1 = z n 2 + c z_{n + 1} = z_n^2 + c zn+1​=zn2​+c
#!/usr/local/bin/python
# -*- coding: gbk -*-
# TEST1.PY                     -- by Dr. ZhuoQing 2020-06-10
# Note:
from headm import *
import pylab as pl
from matplotlib             import cm
def iter_point(c):
    z = c
    for i in range(1, 100):
        if abs(z) > 2: break
        z = z*z+c
    return i
def draw_mandelbrot(cx, cy, d):
    x0, x1, y0, y1 = cx-d, cx+d, cy-d, cy+d
    y, x = ogrid[y0:y1:200j, x0:x1:200j]
    c = x + y*1j
    start = time.process_time()
    mandelbrot = frompyfunc(iter_point, 1, 1)(c).astype(float)
    printf('Time=%f'%(time.process_time() - start))
    pl.imshow(mandelbrot, cmap=cm.jet, extent=[x0, x1, y0, y1])
    pl.gca().set_axis_off()
x,y = 0.27322626, 0.595153338
plt.subplot(231)
draw_mandelbrot(-0.5, 0, 1.5)
for i in range(2, 7):
    pl.subplot(230+i)
    draw_mandelbrot(x, y, 0.2**(i - 1))
pl.subplots_adjust(0.0, 0, 1, 1, 0.0, 0)
pl.show()
#        END OF FILE : TEST1.PY
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
02分形树叶
# TEST2.PY                     -- by Dr. ZhuoQing 2020-06-10
# Note:
from headm import *
import numpy as np
import matplotlib.pyplot as pl
import time
# 蕨类植物叶子的迭代函数和其概率值
eq1 = np.array([[0,0,0],[0,0.16,0]])
p1 = 0.01
eq2 = np.array([[0.2,-0.26,0],[0.23,0.22,1.6]])
p2 = 0.07
eq3 = np.array([[-0.15, 0.28, 0],[0.26,0.24,0.44]])
p3 = 0.07
eq4 = np.array([[0.85, 0.04, 0],[-0.04, 0.85, 1.6]])
p4 = 0.85
def ifs(p, eq, init, n):
    进行函数迭代
    p: 每个函数的选择概率列表
    eq: 迭代函数列表
    init: 迭代初始点
    n: 迭代次数
    返回值: 每次迭代所得的X坐标数组, Y坐标数组, 计算所用的函数下标
    # 迭代向量的初始化
    pos = np.ones(3, dtype=np.float)
    pos[:2] = init
    # 通过函数概率,计算函数的选择序列
    p = np.add.accumulate(p)
    rands = np.random.rand(n)
    select = np.ones(n, dtype=np.int)*(n-1)
    for i, x in enumerate(p[::-1]):
        select[rands<x] = len(p)-i-1
    # 结果的初始化
    result = np.zeros((n,2), dtype=np.float)
    c = np.zeros(n, dtype=np.float)
    for i in range(n):
        eqidx = select[i] # 所选的函数下标
        tmp = np.dot(eq[eqidx], pos) # 进行迭代
        pos[:2] = tmp # 更新迭代向量
        # 保存结果
        result[i] = tmp
        c[i] = eqidx
    return result[:,0], result[:, 1], c
start = time.clock()
x, y, c = ifs([p1,p2,p3,p4],[eq1,eq2,eq3,eq4], [0,0], 100000)
time.clock() - start
pl.figure(figsize=(6,6))
pl.subplot(121)
pl.scatter(x, y, s=1, c="g", marker="s", linewidths=0)
pl.axis("equal")
pl.axis("off")
pl.subplot(122)
pl.scatter(x, y, s=1,c = c, marker="s", linewidths=0)
pl.axis("equal")
pl.axis("off")
pl.subplots_adjust(left=0,right=1,bottom=0,top=1,wspace=0,hspace=0)
pl.gcf().patch.set_facecolor("#D3D3D3")
pl.show()
#        END OF FILE : TEST2.PY
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
文章来源: zhuoqing.blog.csdn.net,作者:卓晴,版权归原作者所有,如需转载,请联系作者。
原文链接:zhuoqing.blog.csdn.net/article/details/106655010
