Chirp信号公式与对离散生成算法之间的差异
tsinghuazhuoqing 发表于 2021/12/27 00:04:04 2021/12/27
【摘要】 讨论产生线性频率变化的公式和它的离散公式之间的差异,并提出Chirp信号的修改方案。 Chirp信号的公式 对于固定频率 ...
Chirp信号的公式
对于固定频率 f 1 f_1 f1​的信号,它的表达式为: r ( t ) = cos ⁡ ( 2 π ⋅ f 1 ⋅ t ) r\left( t \right) = \cos \left( {2\pi \cdot f_1 \cdot t} \right) r(t)=cos(2π⋅f1​⋅t)
其中正弦信号中的相位是频率对时间的积分: θ ( t ) = 2 π ⋅ ∫ 0 t f 1 ⋅ d τ = 2 π ⋅ f 1 ⋅ t \theta \left( t \right) = 2\pi \cdot \int_0^t {f_1 \cdot d\tau } = 2\pi \cdot f_1 \cdot t θ(t)=2π⋅∫0t​f1​⋅dτ=2π⋅f1​⋅t
Chirp信号的频率是变化的,一种最简单的变化就是线性变化,从开始 t = t 0 t = t_0 t=t0​的频率 f s t a r t f_{start} fstart​,一直线性变化到 t = t 1 t = t_1 t=t1​时的频率 f e n d f_{end} fend​。那么任何时刻的频率值为: f ( t ) = f e n d − f s t a r t t 1 − t 0 ⋅ t + f s t a r t f\left( t \right) = {{f_{end} - f_{start} } \over {t_1 - t_0 }} \cdot t + f_{start} f(t)=t1​−t0​fend​−fstart​​⋅t+fstart​
对应的正弦信号相角为: θ ( t ) = 2 π ⋅ ∫ t 0 t 1 f ( τ ) d τ = 2 π ∫ t 0 t 1 f e n d − f s t a r t t 1 − t 0 ⋅ τ + f s t a r t d τ \theta \left( t \right) = 2\pi \cdot \int_{t_0 }^{t_1 } {f\left( \tau \right)d\tau } = 2\pi \int_{t_0 }^{t_1 } {{{f_{end} - f_{start} } \over {t_1 - t_0 }} \cdot \tau + f_{start} d\tau } θ(t)=2π⋅∫t0​t1​​f(τ)dτ=2π∫t0​t1​​t1​−t0​fend​−fstart​​⋅τ+fstart​dτ = 2 π [ f e n d − f s t a r t t 1 − t 0 ⋅ 1 2 ( t 2 − t 0 2 ) + f s t a r t ( t − t 0 ) ] = 2\pi \left[ {{{f_{end} - f_{start} } \over {t_1 - t_0 }} \cdot {1 \over 2}\left( {t_{}^2 - t_0^2 } \right) + f_{start} \left( {t_{} - t_0 } \right)} \right] =2π[t1​−t0​fend​−fstart​​⋅21​(t2​−t02​)+fstart​(t​−t0​)]
如果假设 t 0 = 0 t_0 = 0 t0​=0,那么上面的公式就是: θ ( t ) = 2 π [ f e n d − f s t a r t t 1 ⋅ 1 2 t 2 + f s t a r t ⋅ t ] \theta \left( t \right) = 2\pi \left[ {{{f_{end} - f_{start} } \over {t_1 }} \cdot {1 \over 2}t^2 + f_{start} \cdot t} \right] θ(t)=2π[t1​fend​−fstart​​⋅21​t2+fstart​⋅t]
所以,Chirp信号的公式为:
r ( t ) = cos ⁡ [ 2 π ⋅ ( f e n d − f s t a r t t 1 ⋅ 1 2 t 2 + f s t a r t ⋅ t ) ] r\left( t \right) = \cos \left[ {2\pi \cdot \left( {{{f_{end} - f_{start} } \over {t_1 }} \cdot {1 \over 2}t^2 + f_{start} \cdot t} \right)} \right] r(t)=cos[2π⋅(t1​fend​−fstart​​⋅21​t2+fstart​⋅t)]
下面是在智能车比赛中相应的参数:
起始时间: t 0 = 0 s t_0 = 0s t0​=0s
结束时间: t 1 = 0.2048 s t_1 = 0.2048s t1​=0.2048s
起始频率: f s t a r t = 250 H z f_{start} = 250Hz fstart​=250Hz
结束频率: f e n d = 2000 H z f_{end} = 2000Hz fend​=2000Hz
利用时间间隔 t s = 1 / f s = 100 μ s t_s = 1/f_s = 100\mu s ts​=1/fs​=100μs对该信号进行离散化,得到的波形为:
▲ 通过上述公式产生的Chirp信号波形
def chirpf(t):
    return cos(2*pi*((fend-fstart)/t1*0.5*t*t+fstart*t))
使用MATLAB产生的Chirp信号波形:
▲ 由MATLAB产出的Chirp信号
▲ 由MATLAB产出的Chirp信号
tend=0.2048
fs = 1e4
fstart=250
fend=2000
tdim = 0:1/fs:(tend-1/fs)
chirpdim=chirp(tdim,fstart,tend,fend)
▲ 由SCIPY产出的Chirp信号
▲ 由SCIPY产出的Chirp信号
import scipy.signal
data = scipy.signal.chirp(tdim, fstart,t1, fend)
通过数值对比,可以看到上面三种方式得到的Chirp信号的误差为0。下图显示了公式所计算得到的Chirp信号与MATLAB所产生的Chirp信号的差值。其中微小的误差可能来源于MATLAB结果经过clipboard剪切板之后,数值显示精度降低所引起的。
另外一部分则可能是对于数据的的最后一点的频率微小差异的定义。
▲ 由公式得到的Chirp信号与MATLAB的结果差别
Chirp信号离散生成算法
下面是智能车竞赛信号板单片机通过DAC输出Chirp信号对输出信号buffer进行初始化的程序。
void InitDACBuffer(float fStartF, float fEndF) {
    float fAngle = 0;
    float fFrequency;
    float fDeltaT = 1.0 / DAC_OUTPUT_FREQUENCY;
    int i;
    for(i = 0; i < DAC_BUFFER; i ++) {
        g_nDACBuffer[i] = (unsigned short)((sin(fAngle * 2 * 3.1415926) + 1.0) / 2 * 0x4ff)+0x100;
        fFrequency = (fEndF - fStartF) * (i + 1) / DAC_BUFFER + fStartF;
        fAngle += fFrequency * fDeltaT;
在程序初始化期间调用如下命令:
    InitDACBuffer(250, 2000);
根据上面产生的程序,下面绘制出对应的波形:
▲ 通过离散迭代产生的Chirp信号
▲ 通过离散迭代产生的Chirp信号
DAC_BUFFER = 2048
dacbuf = []
angle = 0
deltat = 1/1e4
for i in range(0, DAC_BUFFER):
    data = cos(angle*2*pi)
    dacbuf.append(data)
    frequency = (fend - fstart) * (i + 1) / DAC_BUFFER + fstart
    angle = angle + frequency * deltat
plt.plot(tdim, dacbuf)
plt.xlabel('Time(s)')
plt.ylabel('Amplitude')
plt.grid(True)
plt.show()
对比由离散程序所产生的数据与前面通过公式计算出的波形,可以看到它们之间存在着差异。下面将公式所计算出的数值与前面程序所产生信号相加,所得到的误差信号:
▲ 公式产生的Chirp信号与程序产生的信号之间的误差
使用程序产生Chirp信号的时候,信号的相位是通过离散积分而得到的,其中所出现的积分误差随着时间增加而叠加,最终使得所产生的信号的相位与实际的相位越来越大,信号的差别,也就增加了。
修改方案
将最终信号Chirp生成的公式修改为:
t n = n ⋅ t s = n f s = n ⋅ 1 0 − 4 t_n = n \cdot t_s = {n \over {f_s }} = n \cdot 10^{ - 4} tn​=n⋅ts​=fs​n​=n⋅10−4
x [ n ] = sin ⁡ [ 2 π ⋅ ( f e n d − f s t a r t t 1 ⋅ 1 2 t n 2 + f s t a r t ⋅ t n ) ] x\left[ n \right] = \sin \left[ {2\pi \cdot \left( {{{f_{end} - f_{start} } \over {t_1 }} \cdot {1 \over 2}t_n^2 + f_{start} \cdot t_n } \right)} \right] x[n]=sin[2π⋅(t1​fend​−fstart​​⋅21​tn2​+fstart​⋅tn​)]
使用sin信号的目的,就是防止最初的信号开始的跳变。根据上面公式所产生的波形为:
▲ 最终定义的Chirp信号的波形
▲ 最终定义的Chirp信号的波形
生成12bit DAC转换对应的数据:
for i in range(DAC_BUFFER):
    tn = i / fs
    angle = (fend-fstart)/t1 * tn * tn / 2 + fstart * tn
    datasin = sin(2*pi*angle)
    dataint16 = int((datasin + 1.0) / 2 * 0x4ff + 0x100)
    dacbuf.append(dataint16)
信号波形为:
▲ 12bit对应的信号波形
▲ 12bit对应的信号波形
▲ 生成8bit DAC对应的波形
▲ 生成8bit DAC对应的波形
▲ 生成7bit DAC对应的波形
▲ 生成7bit DAC对应的波形
▲ 生成6bit DAC对应的波形
▲ 生成6bit DAC对应的波形
生成相关的整型信号,便于MCU输出模拟信号:
fstart = 250
fend = 2000
t0 = 0
t1 = 0.2048
ts = 100e-6
tdim = linspace(t0, t1, int((t1-t0)/ts), endpoint=False)
DAC_BUFFER = 2048
dacbuf = []
fs = 1e4
    tn = i / fs
    dataint16 = int((datasin + 1.0) / 2 * 0x3f)
tspsave('chirp6bit', dacbuf=dacbuf)
下面是将NPZ数据转换成C51的变量的程序。
dacbuf0 = tspload('chirp8bit', 'dacbuf')
dacbuf1 = tspload('chirp7bit', 'dacbuf')
dacbuf2 = tspload('chirp6bit', 'dacbuf')
pastestr = 'unsigned char const code g_ucChirpData[] = {\r\n'
linenumber = 16
lines = int(len(dacbuf2) / linenumber)
for i in range(lines):
    linedata = 127 - dacbuf2[i * linenumber : (i + 1) * linenumber]
    datastr = str(linedata).strip('[]').split(' ')
    datastr1 = [s for s in datastr if len(s) > 0]
    linestr = ','.join(datastr1).lstrip(',') + ',\r\n'
    pastestr = pastestr + '    ' + linestr
pastestr = pastestr + '};\r\n'
clipboard.copy(pastestr)
printf(pastestr)
文章来源: zhuoqing.blog.csdn.net,作者:卓晴,版权归原作者所有,如需转载,请联系作者。
原文链接:zhuoqing.blog.csdn.net/article/details/105762739
