MAX487制作RS485总线接口模块
tsinghuazhuoqing 发表于 2021/12/26 00:22:04 2021/12/26
【摘要】   ■ MAX487简介 MAX487是用于低功耗RS-485总线收发器。 ▲ MAX487管脚配置和典型应用电路 存在的问题: 是否需要增加偏置电阻?在MAX487输...
■ MAX487简介
▲ MAX487管脚配置和典型应用电路
▲ MAX487管脚配置和典型应用电路
存在的问题:
  • 是否需要增加偏置电阻?在MAX487输出低电平的时候两线的差分是多少?
  • 测量总线电压与输出电压之间的关系
01实验电路设计
1.电路设计
▲ 实验电路原理图
▲ 实验电路原理图
▲ 实验电路板PCB
▲ 实验电路板PCB
02电路测量
1.MAX487静态电压
  • 输出电压Vab=0.0035V
  • RXD: 5V
2.Spipex485EEN静态电压
  • 输出电压:Vab=0.0028V
  • RXD: 0.0001V
3.电路输入输出之间的关系
□ MAX487输入输出电压关系
▲ 输入和输出之间的关系
▲ MAX487输入和输出之间的关系
inv=[5.11,5.11,5.11,5.11,5.11,5.11,5.11,5.11,3.30,3.29,3.28,3.27,3.26,3.25,3.24,3.23,3.22,3.21,3.20,3.19,3.18,3.16,3.15,3.15,3.14,3.13,3.12,3.11,3.10,3.09,3.08,3.07,3.06,3.05,3.04,3.03,3.02,3.01,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00]
outv=[-0.00,-0.00,-0.01,-0.01,-0.01,-0.01,-0.01,-0.02,-0.02,-0.02,-0.02,-0.02,-0.02,-0.03,-0.03,-0.03,-0.03,-0.03,-0.04,-0.04,-0.04,-0.04,-0.04,-0.05,-0.05,-0.05,-0.05,-0.05,-0.06,-0.06,-0.06,-0.06,-0.06,-0.07,-0.07,-0.07,-0.07,-0.08,-0.08,-0.08,-0.08,-0.09,-0.09,-0.09,-0.09,-0.09,-0.09,-0.10,-0.10,-0.10]
▲ MAX487输入输出之间的电压关系
▲ MAX487输入输出之间的电压关系
□ Sipex485输入输出之间的关系
▲ Sipexl485输入输出之间的关系
inv=[0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.95,1.11,1.23,1.33,1.41,1.50,1.60,1.68,1.75,1.82,1.90,1.97,2.04,2.12,2.20,5.11,5.11,5.11,5.11,5.11,5.11,5.11,5.11,5.11,5.11]
outv=[0.00,0.00,0.01,0.01,0.02,0.02,0.02,0.03,0.03,0.04,0.04,0.05,0.05,0.05,0.06,0.06,0.07,0.07,0.07,0.08,0.08,0.09,0.09,0.09,0.10,0.10,0.11,0.11,0.11,0.12,0.12,0.13,0.13,0.14,0.14,0.14,0.15,0.15,0.15,0.16,0.16,0.17,0.17,0.18,0.18,0.18,0.19,0.19,0.20,0.20]
03输入输出之间动态关系
1. TXD←总线
在485总线B端加入交流信号。A端接地。测量RO的输出波形。
▲ 测量电路
▲ 测量电路
测量信号波形:
▲ 输入波形和输出波形
▲ 输入波形和输出波形
2.TXD→总线
  • <font size=5>补充这个实验</font>
▲ 测量TXD到VAB之间的传递关系
▲ 测量TXD到VAB之间的传递关系
▲ TXD→Vab
▲ TXD → Vab
▲ TXD → Vab
▲ TXD → Vab
▲ TXD → Vab
▲ TXD → Vab
▲ TXD → Vab
▲ TXD → Vab
在上面测量过程中,MAX487在输出电压转换过程中出现了输入输出电压非单调变化的情况。对于这个原因初步猜测是输入电流的增加,使得输入电压微微下降。
下面在输入Vtxd:串联一个200Ω的电阻,测量其两端的电压,反映了输入电流的变化。
下面是给出了相应的曲线,可以看到输入电流的确是在输出反转前后出现了一定的波动,但这种波动(十几个微安)很小,应该不足以引起输入电压的变化。
▲ 在电压转换过程中的输入电流Vi变化情况
★ 疑问:那么这其中究竟什么原因造成了前面的数据曲线?现在还不可而知。
※ 结论
  1. 对于MAX487组成的总线不需要另行进行偏置。Va<Vb 20mV之后,才有输出反转。
  2. 对于Sipex485则需要进行总线偏置。它的输出在0V左右的时候呈现接收为低电平。
#!/usr/local/bin/python
# -*- coding: gbk -*-
# TEST2.PY                     -- by Dr. ZhuoQing 2020-07-12
# Note:
from headm import *
from tsmodule.tsvisa        import *
from tsmodule.tsstm32       import *
tspbeep(1200, 200)
dp1308open()
dp1308p6v(0)
tspbeep(1200, 200)
time.sleep(1)
inputv = []
outputv = []
setv = linspace(0, 0.1, 50)
for v in setv:
    dp1308p6v(v)
    time.sleep(1)
    meter = meterval()
    outputv.append(meter[2])
    inputv.append(meter[0])
    printf(meter)
tspsave('measure', inv=inputv, outv=outputv)
plt.plot(outputv, inputv)
plt.xlabel("Input(V)")
plt.ylabel("Output(V)")
plt.grid(True)
plt.tight_layout()
plt.show()
#        END OF FILE : TEST2.PY
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
文章来源: zhuoqing.blog.csdn.net,作者:卓晴,版权归原作者所有,如需转载,请联系作者。
原文链接:zhuoqing.blog.csdn.net/article/details/107305794
