学生信息管理系统优化(一)【限制字符,限制输入密码次数】
翟文彪 发表于 2021/12/25 23:24:08 2021/12/25
【摘要】 1.提示三次输入错误密码,自动退出程序 Private Sub cmdOK_Click() Dim txtSQL As String Dim mrc As ADODB.Recordset...
1.提示三次输入错误密码,自动退出程序
    Dim MsgText As String
    UserName = ""
    If Trim(txtUserName.Text = "") Then
        MsgBox "没有这个用户,请重新输入用户名!", vbOKOnly + vbExclamation, "警告"
        txtUserName.SetFocus
    Else
    txtSQL = "select * from user_Info where user_ID = '" & txtUserName.Text & "'"
    Set mrc = ExecuteSQL(txtSQL, MsgText)
        If mrc.EOF Then
            miCount = miCount + 1
            If miCount = 1 Then
                MsgBox "用户名错误,您还有两次机会!", vbOKOnly + vbExclamation, "警告"
                Exit Sub
            End If
            If miCount = 2 Then
               MsgBox "用户名错误,您还有一次机会!", vbOKOnly + vbExclamation, "警告"
               Exit Sub
            End If
            If miCount = 3 Then
               MsgBox "用户名错误,即将退出系统!", vbOKOnly + vbExclamation, "警告"
               End
            End If
        Else
            If Trim(mrc.Fields(1)) = Trim(txtPassWord.Text) Then
                OK = True
                mrc.Close
                Me.Hide
                UserName = Trim(txtUserName.Text)
                FrmMain.Show
            Else
                If miCount = 1 Then
                    MsgBox "密码错误,您还有两次机会!", vbOKOnly + vbExclamation, "警告"
                    txtPassWord.SetFocus
                    Exit Sub
                End If
                If miCount = 2 Then
                   MsgBox "密码错误,您还有一次机会!", vbOKOnly + vbExclamation, "警告"
                   Exit Sub
                End If
                If miCount = 3 Then
                   MsgBox "密码错误,即将退出系统!", vbOKOnly + vbExclamation, "警告"
                   End
                End If
            End If
        End If
    End If
End Sub
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
2.修改各个文本框的输入字符的长度
通过修改属性的中的Maxlengh来实现
3.所有的姓名文本框均要限制只能添加汉字
实现代码:
Private Sub txtSID_KeyPress(KeyAscii As Integer)
Select Case KeyAscii
Case Is < 0, &H20, &H8
Case Else
KeyAscii = 0
MsgBox “姓名只能输入汉字”
End Select
End Sub
4.所有班号,教室,成绩,电话都限制只能添加数字
If KeyAscii >= 48 And KeyAscii <= 57 Or KeyAscii = 8 Then
    Else
       KeyAscii = 0
       MsgBox "只能输入数字!"
    End If
5.限制输入非法字符
实现代码:
  If ((KeyAscii >= 48 And KeyAscii <= 57) Or (KeyAscii >= 65 And KeyAscii <= 90) Or _
      (KeyAscii >= 97 And KeyAscii <= 122) Or (KeyAscii = 8)) = False Then
      KeyAscii = 0
      MsgBox "禁止输入非法字符!", vbOKOnly, "警告"
  End If
文章来源: blog.csdn.net,作者:翟文彪,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/zwb568/article/details/99708742
