使用ABAP代码创建S/4HANA里的Sales Order
汪子熙 发表于 2021/12/25 20:51:36 2021/12/25
【摘要】 下图是使用ABAP代码创建的S/4HANA的Sales Order的截图:其中红色区域的值是我代码里硬编码的,而蓝色是函数SD_SALESDOCUMENT_CREATE自己创建的。来看下代码:DATA: ls_header TYPE bapisdhd1,ls_headerx TYPE bapisdhd1x,lt_bapiret2 LIKE bapiret2 ...
来看下代码:
lt_bapiret2     LIKE bapiret2   OCCURS 0 WITH HEADER LINE,
po_order_number TYPE bapivbeln-vbeln,
lt_partners     TYPE TABLE OF bapiparnr,
ls_partners     LIKE LINE OF lt_partners.
ls_header-serv_date = '20200101'.
ls_header-doc_type = 'TA'. “销售订单的类型
ls_header-comp_cde_b = '0001'. ” 公司代码
ls_headerx-comp_cde_b = 'X'.
ls_headerx-doc_type = 'X'.
ls_headerx-updateflag = 'I'. “ 指定修改模式为I-创建
ls_partners-partn_role = 'WE'. "ship to party
ls_partners-partn_numb = '0000000001'. ”这个客户主数据在数据库表KNA1里必须存在
APPEND ls_partners TO lt_partners.
ls_partners-partn_role = 'AG'. " sold to party
“调用BAPI:
CALL FUNCTION 'SD_SALESDOCUMENT_CREATE'
EXPORTING
sales_header_in       = ls_header
sales_header_inx      = ls_headerx
int_number_assignment = 'X'
IMPORTING
salesdocument_ex      = po_order_number
TABLES
return                = lt_bapiret2
sales_partners        = lt_partners.
LOOP AT lt_bapiret2 ASSIGNING FIELD-SYMBOL(<return>) WHERE type = 'E'.
WRITE:/ 'Error:', <return>-message COLOR COL_NEGATIVE.
RETURN.
ENDLOOP.
IF po_order_number IS INITIAL.
WRITE:/ 'PO number initial'.
RETURN.
ENDIF.
CLEAR: lt_bapiret2.
CALL FUNCTION 'BAPI_TRANSACTION_COMMIT'
EXPORTING
wait   = 'X'
IMPORTING
return = lt_bapiret2.
事务码MM03查看物料主数据,如下图所示的行项目数据,包含物料ID,描述信息,数量,单价等等:
使用如下代码进行行项目读取:
DATA: ls_read   TYPE order_view,
lt_item   TYPE TABLE OF bapisdit,
lt_header TYPE table of sales_key.
APPEND INITIAL LINE TO lt_header ASSIGNING FIELD-SYMBOL(<header>).
" 代表读取行项目
ls_read-item = 'X'.
" 传入Sales Order的ID
<header>-vbeln = '0000000268'.
CALL FUNCTION 'BAPISDORDER_GETDETAILEDLIST'
EXPORTING
i_bapi_view     = ls_read
TABLES
sales_documents = lt_header
order_items_out = lt_item.
输出的行项目信息保存在内表lt_item里:
其中字段MATL_GROUP: 物料组,类型为MATKL,value table T023,
ITEM_CATEG: item category。类型为PSTYV,value table TVPT
TAN代表standard item:
REL_FOR_BI:代表这个销售订单是否和billing有关,类型FKREL。
要获取更多Jerry的原创文章,请关注公众号"汪子熙"。
