Python运用webbrowser打开PyEcharts生成的html文件
府学路18号车神 发表于 2021/12/24 22:36:59 2021/12/24
【摘要】 话不多说,直接上代码 这里 也有更多pyecharts的代码~ 示例 调用库 import pandas as pd import time from functools import parti...
话不多说,直接上代码
示例
调用库
import pandas as pd
import time
from functools import partial
from PyQt5.QtWidgets import *
from PyQt5 import QtCore, QtGui, QtWidgets
from pyecharts import options as opts
from pyecharts.charts import Kline, Line, Bar, Grid
import webbrowser as wb
K线图、输出在默认浏览器显示
# 移动平均数计算
def moving_average(data, day_count):
    data = data.values[:, 0]
    result = []
    for i in range(len(data)):
        start_day_index = i - day_count + 1
        if start_day_index <= 0:
            start_day_index = 0
        justified_day_count = i - start_day_index + 1
        mean = data[start_day_index:i + 1].sum() / justified_day_count
        result.append(mean)
    return result
# k线             --项目需求:已实现--
def show_kline(csv_name):
    # 读取.csv文件,
    stock_code = 'Brent_OIL'
    stock_data = pd.read_csv(csv_name, encoding='gb2312')
    # 将文件内容按照by=[‘date’]内容进行排序
    stock_data = stock_data.sort_values(by=["date"], ascending=[True], inplace=False)
    stock_data_cleared = stock_data[stock_data['close'] > 0]
    stock_name = stock_data_cleared["position"][0]
    stock_data_extracted = stock_data_cleared[["open", "close", "low", "high", "volume", "date"]]
    kline = (
        Kline()
            .add_xaxis(stock_data_extracted["date"].values.tolist())
            .add_yaxis("K线图", stock_data_extracted.iloc[:, :4].values.tolist())
            .set_global_opts(
            xaxis_opts=opts.AxisOpts(is_scale=True, is_show=False),
            # axis_opts=opts.AxisOpts(is_scale=True,min_=0), #y轴起始坐标可以设为0
            yaxis_opts=opts.AxisOpts(is_scale=True),  # y轴起始坐标可自动调整
            #title_opts=opts.TitleOpts(title="价格", subtitle=stock_name + "\n" + stock_code, pos_top="20%"),
            axispointer_opts=opts.AxisPointerOpts(
                is_show=True,
                link=[{"xAxisIndex": "all"}],
                label=opts.LabelOpts(background_color="#777"),
            datazoom_opts=[  # 设置zoom参数后即可缩放
                opts.DataZoomOpts(
                    is_show=True,
                    type_="inside",
                    xaxis_index=[0, 1],  # 设置第0轴和第1轴同时缩放
                    range_start=0,
                    range_end=100,
                opts.DataZoomOpts(
                    is_show=True,
                    xaxis_index=[0, 1],
                    type_="slider",
                    pos_top="90%",
                    range_start=0,
                    range_end=100,
    # 移动平均线
    line = (
        Line()
            .add_xaxis(xaxis_data=stock_data_extracted["date"].values.tolist())
            .add_yaxis(
            series_name="MA5",
            y_axis=moving_average(stock_data_extracted[["close"]], 5),
            is_smooth=True,
            is_hover_animation=False,
            linestyle_opts=opts.LineStyleOpts(width=1, opacity=0.5),
            label_opts=opts.LabelOpts(is_show=False),
            .add_yaxis(
            series_name="MA10",
            y_axis=moving_average(stock_data_extracted[["close"]], 10),
            is_smooth=True,
            .add_yaxis(
            series_name="MA30",
            y_axis=moving_average(stock_data_extracted[["close"]], 30),
            is_smooth=True,
            .add_yaxis(
            series_name="MA60",
            y_axis=moving_average(stock_data_extracted[["close"]], 60),
            is_smooth=True,
            .add_yaxis(
            series_name="MA120",
            y_axis=moving_average(stock_data_extracted[["close"]], 120),
            is_smooth=True,
            .add_yaxis(
            series_name="MA240",
            y_axis=moving_average(stock_data_extracted[["close"]], 240),
            is_smooth=True,
            .add_yaxis(
            series_name="MA360",
            y_axis=moving_average(stock_data_extracted[["close"]], 360),
            is_smooth=True,
            .set_global_opts(xaxis_opts=opts.AxisOpts(type_="category"))
    # 将K线图和移动平均线显示在一个图内
    kline.overlap(line)
    # 成交量柱形图
    x = stock_data_extracted[["date"]].values[:, 0].tolist()
    y = stock_data_extracted[["volume"]].values[:, 0].tolist()
    bar = (
        Bar()
            .add_xaxis(x)
            .add_yaxis("成交量", y, label_opts=opts.LabelOpts(is_show=False),
                       itemstyle_opts=opts.ItemStyleOpts(color="#008080"))
            .set_global_opts(title_opts=opts.TitleOpts(title="成交量", pos_top="70%"),
                             legend_opts=opts.LegendOpts(is_show=False),
    # 使用网格将多张图标组合到一起显示
    grid_chart = Grid()
    grid_chart.add(
        kline,
        grid_opts=opts.GridOpts(pos_left="15%", pos_right="8%", height="55%"),
    grid_chart.add(
        bar,
        grid_opts=opts.GridOpts(pos_left="15%", pos_right="8%", pos_top="70%", height="20%"),
    htl = csv_name + ".html"
    grid_chart.render(htl)
    wb.open(htl)
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
主函数
def click_success(self):
    print("数据获取成功!")
    csv_name1 = 'outside_brent_oil.csv'
    outside_history_brent_oil_data().to_csv(csv_name1, index=False)
    show_kline(csv_name1)
    # html_success()
def click_success_3(self):
    print("数据获取成功!")
    csv_name2 = 'outside_newyork_oil.csv'
    outside_history_newyork_oil_data().to_csv(csv_name2, index=False)
    show_kline(csv_name2)
def click_success_4(self):
    print("数据获取成功!")
    csv_name3 = 'outside_newyork_gas.csv'
    outside_history_newyork_natural_gas_data().to_csv(csv_name3, index=False)
    show_kline(csv_name3)
if __name__ == '__main__':
    app = QApplication(sys.argv)
    MainWindow = QMainWindow()
    ui = Ui_MainWindow()
    ui.setupUi(MainWindow)
    MainWindow.show()
     # 外盘期货
    ui.pushButton.clicked.connect(click_success)           # 布伦特原油期货分析图
    ui.pushButton_3.clicked.connect(click_success_3)       # 纽约原油期货分析图
    ui.pushButton_4.clicked.connect(click_success_4)       # 纽约天然气期货分析图
    sys.exit(app.exec_())
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
其中实现跳转代码为
    wb.open(htl)
所以不用老去纠结每件事
集中精力完成眼前的事情的过程中
愿望自然就会实现了吧。
【纯·干货】你会用到的论文小助手,不定期持续更新中~
文章来源: blog.csdn.net,作者:府学路18号车神,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/weixin_44333889/article/details/117920091
