C# 属性设置
AI浩 发表于 2021/12/22 23:54:09 2021/12/22
【摘要】 将属性设置为对外访问只读,对内可写,同时设置默认值。举例: public string DL_PointA { get; private set; } = "2054325"; 初始化字典类型的属性:  private static Dictionary<string, string> _scs_Dic; &...
初始化字典类型的属性:
        public static Dictionary<string, string> scs_Dic
            get
                if (_scs_Dic == null)
                    _scs_Dic = new Dictionary<string, string>();
                return _scs_Dic;
            private set { value = _scs_Dic; }
文章来源: wanghao.blog.csdn.net,作者:AI浩,版权归原作者所有,如需转载,请联系作者。
原文链接:wanghao.blog.csdn.net/article/details/107104152
